Made some new shock top mounts for my rear coilovers
Posted: Thu Apr 01, 2010 11:00 pm
by gareth
I've been tinkering at work and have knocked up some offset rear top mounts :)
the original Leda units are modified BMW jobbies with a solid centre welded into the original steel housing. the spherical (rose) bearing is central in the mount and doesn't allow enough clearance between the spring and inner wing. a lot of folks attack the mounting on the chassis to move them outwards but i don't like the idea of slotted holes, especially on a lardy touring. Also, being a touring it's a real pain having to remove half of the interior every time i need to access the mounts, so i produced these little babies. the shock can be removed by removing the bearing retaining screws from under the arch, saving loads of time and making spring rate swaps a 15 minute job :D
made from stainless steel 431 (all we really use at work) with a 5mm offset within the mount. the linisher i used to deburr has left a few lights marks that have caught on the flash but they look spot under normal light :D
Re: Made some new shock top mounts for my rear coilovers
Posted: Fri Apr 02, 2010 3:43 am
by Brian28
Top work Gareth. If you are thinking of machining a few up for resale I'd imagine a ready market for them.
Posted: Fri Apr 02, 2010 9:42 am
by UweM3
good thinking mate! If I would run them I would add another retaining screw (are they M6 or M8?).
But this largely depends on how stiff your shocks are. Don't underestimate the rebound forces!
Posted: Fri Apr 02, 2010 10:37 am
by gareth
Cheers of the positive comments :D
Brian, it took me over a year to finish these off so i would't want to take too many orders! :lol:
my bit took very little time but i had to ask one of the lads to produce the profile on the outside for me and we've been busy, and he's unreliable, and i kept forgetting!
They would be a useful thing for someone to make though
Uwe,
there's no space for a 3rd retaining screw without breaking out the side of the 'top hat' section. and yes they are M6 but will be fitted with grade 12.9 fixings.
my rear shocks are coilovers so don't actually 'pull' on the shell in the same way - the spring rebound/damping forces act between the ends of the shock, not between the shock and the chassis.
when you think about it, a coilover setup reduces the load cycling on the rear mounting points considerably over a conventional setup. obviously compression damping loads and spring reactions will be higher but the rebound forces will be lower.
the original leda unit just uses a single circlip to retain the bearing. the specs for this show a pullout load rating of 3.6kN (about 350kg). each M6 screw will safely hold several times that.
Posted: Fri Apr 02, 2010 8:43 pm
by UweM3
I know, I know. I am just a little scared and like to over engineer things. Braces and belt syndrome :mad:
I like the offset position!
Posted: Sat Apr 03, 2010 1:07 am
by gareth
i like to over-engineer too however space wouldn't allow three M6's or two M8's
the stainless steel is 431 and in the right heat treatment state has about the same tensile strength as a grade 12.9 (such as ARP) bolt. not lightweight though but on a 1400kg touring, who cares!
Posted: Sat Apr 03, 2010 7:12 am
by GeoffBob
Hi Gareth, great work.
Sorry, but I must be missing something. Can you please explain to me how it is that you can disconnect the damper by removing the bearing retaining screws. I have sperical bearings on my front turrets and the nut on the top of the damper shaft would prevent the shaft from being withdrawn through the hole in the mount even if the bearing were withdrawn. But then I guess that could just be because of the shape and size of my nuts 8O. If your nuts are small enough to pass through the hole previously occupied by the bearing then it's an entirely different story. Sorry, I guess I just answered my own question :o: . This must be how your idea works?
Great idea BTW.
Regards
Geoff
Posted: Sat Apr 03, 2010 8:58 am
by gareth
i do indeed have significantly smaller nuts. at least i think i do! The measurements were done from memory of the spanner size when i drew them up... over a year ago now though so i can;t rmemember what it is! :P
i'll have to measure them up (ballache to get to them) and if space is tight, i could 'clip' the corners on a lathe if needed
Posted: Sat Apr 03, 2010 9:26 am
by UweM3
GeoffBob wrote:Hi Gareth, great work.
But then I guess that could just be because of the shape and size of my nuts . If your nuts are small enough ......
Geoff
Oii! too much information here, too much! winkeye
Posted: Sat Apr 03, 2010 4:01 pm
by Turbo-Brown
Ooooh spangly! :D
Are they offset to help the coilovers clear the wheels or something like that?
Posted: Sun Apr 04, 2010 1:09 am
by gareth
cheers! :D
They're, offset to help the coilovers clear the inner wings as BMW never left space for springs there. how inconsiderate! :)
Posted: Mon Apr 05, 2010 11:10 am
by gareth
i have them fitted :D
and i do indeed have adequate nut clearance :P
Posted: Mon Apr 05, 2010 2:07 pm
by GeoffBob
gareth wrote:i have them fitted :D
Well done,
If your nuts were a bit tight I was going to suggest smearing on a little lubricant 8O.
Posted: Mon Apr 05, 2010 2:32 pm
by gareth
plenty of lube used, one hard shove and it was up to the nuts in the hole. two quick screws later and it was all tightly fitted up the rear end... :eek: :P
Posted: Mon Apr 05, 2010 2:45 pm
by GeoffBob
gareth wrote:plenty of lube used, one hard shove and it was up to the nuts in the hole. two quick screws later and it was all tightly fitted up the rear end... :eek: :P
:lol:
Dare I even say it,
:ttiwwp:
or possibly better left without :D
Posted: Tue Apr 06, 2010 12:37 am
by gareth
err, best without i reckon! :D
Posted: Mon May 10, 2010 5:04 pm
by randomspeedfreak
so gaz coilovers contact the inner wing when fitted normally?
Re:
Posted: Mon May 10, 2010 6:40 pm
by gareth
I'm not sure on the gaz units specifically but if they don't have eccentric top mounts and do have 2.25" springs, they'll rub.
Re:
Posted: Tue May 11, 2010 2:35 am
by randomspeedfreak
gareth wrote:I'm not sure on the gaz units specifically but if they don't have eccentric top mounts and do have 2.25" springs, they'll rub.
ok thanks
really nice mounts btw.
if u did make a few sets id have one :wink:
Re:
Posted: Tue May 11, 2010 5:03 am
by fowler
garath can i have some please :D
Re:
Posted: Tue May 11, 2010 8:24 am
by Rav335uk
Just clocked this thread, Impressed to say the least that the "Ginger" winkeye does have a Brain.
Good work there Gareth :D
Re:
Posted: Tue May 11, 2010 6:05 pm
by gareth
Rav, i'm not sure if that's a compliment or not! :D
I'm not really able to produce more as it literally took ver a year to get space on the CNC machine and a bloke to do the profile milling for me. plus they'll only fit the wierdo imperial size rose joint used by Leda, not a BMW shock.
RPM do a similar top mount but not eccentric... i reckon they should do an eccentric version really...
Re:
Posted: Tue May 11, 2010 6:13 pm
by Theo
Ground control sell something very similar to these - http://www.ground-control-store.com/pro ... I=656/CA=8
Re:
Posted: Tue May 11, 2010 6:48 pm
by gareth
well spotted that man! :D
Re:
Posted: Fri Apr 29, 2011 11:23 pm
by gareth
Just thought i'd follow this up a year on...
They've not broken and proved themselves very useful on the zone roam 2011 when i lost all of the fluid from a leaking shock seal so i needed to pull one off for a get-me-home top-up.
It took about 20 minutes to get the shock off, refilled and refitted before a day's hooning :cool: I didn't even have to unpack all our gear from the boot :)
Re:
Posted: Fri Apr 29, 2011 11:26 pm
by Topblag
gareth wrote:Just thought i'd follow this up a year on...
..... so i needed to pull one off for a get-me-home top-up...... :)
That's just wrong. :mad:
Re:
Posted: Fri Apr 29, 2011 11:41 pm
by Jozi
Whats all this about the rear topmounts not being able to take a true coilover setup? Or is it not a true coilover setup?
Posted: Fri Apr 29, 2011 11:52 pm
by BadDave
randomspeedfreak wrote:so gaz coilovers contact the inner wing when fitted normally?
Bit late now, but for future referance Gaz Golds come with offset spacers for the bottom mount to allow clearance.
Re:
Posted: Sat Apr 30, 2011 12:01 am
by BadDave
Jozi wrote:Whats all this about the rear topmounts not being able to take a true coilover setup? Or is it not a true coilover setup?
With a coilover setup the rear shock tower takes the hit when the spring compresses and when it goes into rebound.
On tourings there is additional bracing on the shock tower, but the area around the 2 bolt holes suffer from stress fractures over time,hence the addition of Z3 reinforcement plates.
You could still use E46 cab rear topmounts but you'd be replacing them more frequently that you normally would with a standard setup
R/J topmounts are the way to go IMO
Re:
Posted: Sat Apr 30, 2011 12:06 am
by gareth
The fully thing is, on rebound with a coilover setup, the load on the top mount / shell is a load less than a conventional spring setup as the wishbone is not pulling the shock down (loaded by the spring). It's still being pushed down by the spring. This means it's cot a varying compressive load on the top mount, not a cyclic load
A hard concept to grasp without sketching it all out and working out the forces involved.
Re:
Posted: Sat Apr 30, 2011 12:24 am
by Jozi
What do you mean by R/J? Rose jointed?
So I did well getting a touring :) Would this setup be recommended over adjustable spring perches in the conventional location on the trailing arms?
Sorry for straying a little of topic. I was always under the impression coilovers didnt fit because of space in the housing and lack of strength in the towers and so a little interested as coilovers are my next mod on te list.
Gareth: Your right, I don't quite get it :) Get sketching so I can learn :p
Re:
Posted: Sat Apr 30, 2011 12:38 am
by BadDave
Jozi wrote:What do you mean by R/J? Rose jointed?
Yes
Yes
Sorry for straying a little of topic. I was always under the impression coilovers didnt fit because of space in the housing and lack of strength in the towers and so a little interested as coilovers are my next mod on the list.
I have Gaz golds on the rear of my touring with R/J topmounts,Z3 reinforcing plates and offset spacers supplied direct from Gaz.
Had them fitted for 2yrs+.
Re:
Posted: Sun May 01, 2011 5:32 pm
by RPM
All brands of coilovers will foul the fuel breather system on the OSR
As BadDave says the GAZ ones come with an offset spacer on the bottom, and we can also supply offset rear topmounts for the top to clear the breather pipes: http://www.raceperformancemodified.com/ ... -Topmounts
Thanks to Gareth giving us a nudge and some help :)
Re:
Posted: Wed May 04, 2011 8:57 pm
by gareth
No worries :)
