Looking to buy this set...are they any good??
Posted: Thu Oct 29, 2009 9:35 am
by danny_duke01
Hi,
I am looking to upgrade my brakes with new discs and pads as i'm preparing my '90 325 for the track...
I have found this set on ebay and just wondered what you guys think please...do they look any good??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
The price is about what i would like to spend but wondered if any of you knew of any better before i buy...
Thanks in advance guys!!
Danny
Re: Looking to buy this set...are they any good??
Posted: Thu Oct 29, 2009 10:02 am
by Jhonno
I would say standard BMW would be better..
Posted: Thu Oct 29, 2009 11:25 am
by oldbimmer
Would have to agree there - standard BMW discs are of the highest quality. Yes, they aren't grooved or drilled but they will take a lot more abuse than most aftermarket discs I've seen.
In any case, it's often said that drilled discs are prone to cracking..
Having said that though, I have used ATE PowerDiscs (from ECP) to good effect. Cheaper than gen BMW too.
Posted: Thu Oct 29, 2009 6:43 pm
by N00b
danny_duke01 wrote:The price is about what i would like to spend but wondered if any of you knew of any better before i buy...
Danny
For not much more you could get reputable branded parts.
It's been said time and time again, that unless you're fitting larger wheels (allowing for the use of larger diameter discs) then the genuine BMW disc is the one to go for.
Posted: Thu Oct 29, 2009 6:44 pm
by N00b
oldbimmer wrote:Having said that though, I have used ATE PowerDiscs (from ECP) to good effect. Cheaper than gen BMW too.
I've got them on my car at the moment, and am disappointed with them. They fade too easily.
Posted: Thu Oct 29, 2009 6:51 pm
by oldbimmer
N00b wrote:oldbimmer wrote:Having said that though, I have used ATE PowerDiscs (from ECP) to good effect. Cheaper than gen BMW too.
Oh dear, that's a shame.... I seem to remember you were asking about discs some months ago and decided on the powerdiscs.. What pads are you using? (what fluid too?) I've never had any fade with EBC Yellow/ Power Disc combo..
Posted: Thu Oct 29, 2009 7:03 pm
by N00b
oldbimmer wrote:Oh dear, that's a shame.... I seem to remember you were asking about discs some months ago and decided on the powerdiscs.. What pads are you using? (what fluid too?) I've never had any fade with EBC Yellow/ Power Disc combo..
EBC yellows. The fluid was completely renewed but it's not fancy motorsport stuff. I should add that the only place I got them to fail was when on the 'ring, and I was spanking the ass off the car. Other than that they've been great and especially pretty damn quiet.
I'm a bit disappointed TBH mate, as I like to buy right first time.
The BMW parts were double the cost of the ATE's though
Posted: Thu Oct 29, 2009 8:04 pm
by oldbimmer
N00b wrote:oldbimmer wrote:Oh dear, that's a shame.... I seem to remember you were asking about discs some months ago and decided on the powerdiscs.. What pads are you using? (what fluid too?) I've never had any fade with EBC Yellow/ Power Disc combo..
Did you bed them in carefully?? I spend at least 200 miles braking carefully before building up to maximum retardation.
I also use ATE Super Blue fluid.
I guess the only way to know for sure is to try something else next time. I know what you mean though when you say about buying things once. I hate making expensive mistakes but I guess we all do it from time to time.
Posted: Thu Oct 29, 2009 8:13 pm
by danny_duke01
Thanks for all the advice guys!!
I will leave well alone with the discs then at the mo...but i have just ordered some Mintex pads!!
Posted: Thu Oct 29, 2009 8:21 pm
by oldbimmer
Which variety of Mintex did you go for??
Posted: Thu Oct 29, 2009 8:35 pm
by danny_duke01
oldbimmer wrote:Which variety of Mintex did you go for??
Here is the link for the ones i've just bought on ebay...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
I hope they are ok??...i have a '90 325i SE
Posted: Fri Oct 30, 2009 12:58 pm
by Jhonno
They are OEM replacement might as well have popped to your local dealer...
Posted: Fri Oct 30, 2009 6:09 pm
by N00b
oldbimmer wrote:N00b wrote:oldbimmer wrote:Oh dear, that's a shame.... I seem to remember you were asking about discs some months ago and decided on the powerdiscs.. What pads are you using? (what fluid too?) I've never had any fade with EBC Yellow/ Power Disc combo..
I think I'll fit a more effective ducting solution and see if the extra airflow stops fade from rearing its ugly head.
Posted: Sat Oct 31, 2009 5:10 am
by djs325
Drilled rotors = RUN AWAY!!!!
Posted: Sat Oct 31, 2009 10:24 am
by MarkT
There's a lot to be said to using cheaper discs as a disposable item and running a really good high friction set of pads. Yes your going to warp them but then again it's better than buying OE BMW ones and warping them after a couple or three track days.
This is assuming that the OE BMW discs are silly money. Then go with the man Johnno
Posted: Sat Oct 31, 2009 11:35 am
by oldbimmer
I think you might need something a little more heavy duty for track use. For the road however, they'll be fine..
Posted: Sat Oct 31, 2009 12:10 pm
by N00b
MarkT wrote:There's a lot to be said to using cheaper discs as a disposable item and running a really good high friction set of pads. Yes your going to warp them but then again it's better than buying OE BMW ones and warping them after a couple or three track days.
If bedded in properly, discs don't warp unless they've been fitted incorrectly or there's a manufacturing defect present.
MarkT wrote:This is assuming that the OE BMW discs are silly money. Then go with the man Johnno
I "think" a genuine pair of discs is a few quid short of £100.
Posted: Sat Oct 31, 2009 2:18 pm
by billgatese30
No where near £100 notes the last time I bought some.
For prices ask in the genuine parts section on here for a quote as you'll get a small discount from list price too.
Posted: Sat Oct 31, 2009 2:44 pm
by N00b
billgatese30 wrote:No where near £100 notes the last time I bought some.
Looks like it's a little more than I thought, approx £125/pair.
Posted: Sat Oct 31, 2009 7:01 pm
by danny_duke01
Thanks for all the advice guys...well as i bought the Mintex pads,i have since won a set of Mintex discs (brand new boxed) on ebay for £28...cost the seller £130 new,so thought that was a good bargain!!
