Oils
Posted: Sat Aug 01, 2009 7:55 pm
by Rallyprep_UK
Hey there,
What make/type of oil are you using in your M20 track cars and how often would you recommend a change ?
Mines a 2.5 high comp engine for track use only, I have been building it over about a year - another few months and she will be ready to drive :)
Is Mobil1 as good as people make out ???
thanks
will
Re: Oils
Posted: Sun Aug 02, 2009 6:39 pm
by Black_Potato
Most the racers in PBMW run valvoline 20/50 racing, cheap as chips and seems to work for them. Changes vary but most probably do it every few race meets.
Re: Oils
Posted: Sun Aug 02, 2009 6:41 pm
by Rallyprep_UK
:) great thanks !
Re: Oils
Posted: Sun Aug 02, 2009 9:02 pm
by cragles
Like Mr Potato says -we use 20w/50 and change it after every 2 race meetings. (approx 2 hours track time) plus the driving to and from the track
Re: Oils
Posted: Mon Aug 03, 2009 3:55 pm
by Rallyprep_UK
Just ordered some up from Mill Auto Supplies and managed to get a deal for putting their stickers on my car hehe winkeye
Re: Oils
Posted: Mon Aug 03, 2009 7:27 pm
by agent006
I had 5/40 recommended for mine from the guys at Opie oils. I use that on Silkolene Pro-S with no problems. Though if racers are using 20/50 then i may have duff advice.
Re: Oils
Posted: Wed Aug 05, 2009 12:16 am
by scaraveos
Is that 20/50 synthetic or semi-synthetic?
Re: Oils
Posted: Fri Aug 07, 2009 12:55 am
by Black_Potato
That 20/50 is actualy mineral...... hence only £15 or so for 5 ltrs..
Re Silkolene products, used them for years and certainly wouldnt recommend against them but at £50 a pop its not cheap.
Like anything you pays your money you takes your choice.
Re: Oils
Posted: Fri Aug 07, 2009 3:20 am
by djs325
Motul 300V Chrono - 10W40. Dropped 15 degrees of engine temp versus Castrol Edge Sport. Fantastic stuff, 100% Double Ester Synthetic. Goes in clean, comes out clean. I also highly recommend the K&N Performance Gold Oil Filters, part number HP-2005, as these are very good filters, and easy to attach/remove on 325i with their 1" nut on the end, which can also be lockwired on if necessary.
