MJJ_ZX6RR wrote:billgatese30 wrote:Your other option is to drive the car differently. Firstly get an instructor in with you, that will gain you more time than any mod to the car. Then you can look at things like trail braking etc to se the car into the corner more appropriately.
I have to say this is wise advice. I used the services of one of Castle Combe's instructors, and he made me a lot smoother - not sure if it was any faster though.
Previously, I had always trail braked all the way up to the apex, with the obvious challenge this presents in balancing braking effort against turn-in. The instructor was recommending getting all the braking done prior to turn in, then turn in on a neutral throttle. This was obviously much kinder to the car, and I had to fight the car much less, but I only timed myself prior to instruction so cannot comment on improvement, if any.
The previous method of trail braking, getting a little out of shape and torturing tyres was much more fun however.
Martin.
In the earlier stages of track driving then yes, its important to learn to be smooth and that usually means thinking about breaking it down into steps, brake, shift, balance throttle and then turn towards the apex and power through the corner and be smooth on the exit.
Trail braking helps primarily with bends where understeer on turn in is a problem (rather than at the apex or on the exit when you apply the power) and can help quell it so that the correct apex speed can be achieved, but it won't always work on every corner.
If you are smooth then as someone said above, you can practice and lap after lap you will get quicker, if your rough, then it doesn't matter how hard you try, the car will fight back and you will not get quicker.
trail braking isn't about getting sideways into a corner either, it is a very fine balance where you can just say feel it kill the understeer, but if you need to turn the wheel any less than you would to get around the corner with no understeer/oversteer then you've over done it (opposite lock on the way in means you have got it very wrong, but it is fun
), you should just feel the car "tuck in" rather than wash out, but it should not feel like oversteer. It is hard to explain and like playing guitar or heel and toe shifting, you just feel when it is right and everything seems to fall into place and feel natural. It is a very fine line and to begin with I would worry more about being smooth and building speed/pace, rather than trying to master trail braking, but it is a cheap option versus expensive car mods which must be changed between road and track.
Also, don't forget if you add ballast to the boot etc, make sure it is reasonably secured otherwise it will go from side to side on each corner.
