prop mounts
Posted: Fri Nov 09, 2007 12:42 am
by Ziggy
Paul, dya know what the difference is between pre & post facelift prop centre mounts? Are they compatible with each other / do they mount to the car differently?
No worries if you don't know, but on the off chance that you've seen em / got both / just know etc...! I'll post in tech help otherwise.
Cheers mate :)
Re: prop mounts
Posted: Fri Nov 09, 2007 2:34 pm
by zimmerbimmer1
Hi Ziggy,
Unfortunately I could not tell you.
The bearing itself is the same but the part it is in is different so I guess it is mounted differently.
Regards
Paul
Re: prop mounts
Posted: Fri Nov 09, 2007 2:45 pm
by Ziggy
Cheers mate - good info on the bearing anyway; that means either could be fitted to the same prop :thumb:
