Gearbox to exhaust bracket mounting
Posted: Fri May 10, 2013 3:53 pm
by Aziz
Hi
Im after gearbox to exhaust mounting bracket for e36 m3
5 speed box.
Part nos
06 Bracket 1 18311401522 $8.14
07 WAVE WASHER B8 2 07119932095 $0.09
08 Hex Bolt with washer M8X20-Z1-ZNS 2 07119900259 $0.65
09 EXHAUST SUPPORT 1 09/1994 18311404477 $17.29
only in conjunction with
-- CLAMP UPPER D=65,0MM 1 09/1994 18311404478 $10.62
-- CLAMP LOWER D=65,0MM 1 09/1994 18311404479 $10.62
10 Hex Bolt M8X35-8.8-ZNS3 2 07119904252 $0.82
11 RUBBER BUSHING D=8MM 4 18207546579 $2.86
12 Washer A8,4 2 07119900052 $0.11
13 Self-locking hex nut M8 3 07129964655 $0.25
14 CLAMP UPPER D=65,0MM 1 09/1994 18311404478 $10.62
-- EXHAUST SUPPORT 1 09/1994 18311404477 $17.29
15 Hex Bolt M8X16 1 07119913612 $0.62
16 Hex Bolt with washer M8X20-Z1-ZNS 1 07119900259 $0.65
17 Hex Bolt with washer M8X45-Z1 1 07119913000 $0.43
thanks Imran
Re: Gearbox to exhaust bracket mounting
Posted: Mon May 13, 2013 8:45 am
by Cotswoldbmw
Hi There
06 Bracket 1 18311401522 £17.47
07 WAVE WASHER B8 2 07119932095 £0.16
08 Hex Bolt with washer M8X20-Z1-ZNS 2 07119900259 £0.59
09 EXHAUST SUPPORT 1 09/1994 18311404477 £11.17German order 3-5 working days
-- CLAMP UPPER D=65,0MM 1 09/1994 18311404478 £7.75 German order 3-5 working days
-- CLAMP LOWER D=65,0MM 1 09/1994 18311404479 £8.52 German order 3-5 working days
10 Hex Bolt M8X35-8.8-ZNS3 2 07119904252 £0.77
11 RUBBER BUSHING D=8MM 4 18207546579 £2.89
12 Washer A8,4 2 07119900052 £0.23
13 Self-locking hex nut * I tried to use text speak but the text speak filter stopped me * 3 07129964655 £0.49
14 CLAMP UPPER D=65,0MM 1 09/1994 18311404478 Already quoted ^^^^^^
-- EXHAUST SUPPORT 1 09/1994 18311404477 Already quoted ^^^^^^
-- CLAMP LOWER D=65,0MM 1 09/1994 18311404479 Already quoted ^^^^^^
15 Hex Bolt M8X16 1 07119913612 £0.76
16 Hex Bolt with washer M8X20-Z1-ZNS 1 07119900259 Already quoted ^^^^^^
17 Hex Bolt with washer M8X45-Z1 1 07119913000 £0.77
Not sure how many nuts,bolts and washers you require so have only quoted for 1
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 32170
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
