Diff shims
Posted: Fri Dec 30, 2011 10:32 am
by Martin347
Hi,
I am looking for some shims for a BMW E30 medium case diff. Are they available for the pinion? And are they also available for the crown wheel (they sit between the main casing and the caps either side).
Many thanks, Martin.
Re: Diff shims
Posted: Fri Dec 30, 2011 11:05 am
by Cotswoldbmw
Morning Martin. If you go onto real oem and look at page 33_0116 item 7 and 33_1493 item 9 and see if thats what you are after. If that is then you need to tell me which sizes and how many need, i can get them but they will need to come from Germany. Thanks.
regards
Paul.
