quote please (Seals etc)
Posted: Tue Nov 22, 2011 8:24 am
Could you please give me prices for the seals in an E30 medium case diff. Part numbers-
2no 33107505602 (44x67x10mm seal)
1no 33101214099 (45x75x10mm seal)
1no 33111210405 (casing gasket)
Also, if possible the two O rings that seal the output flanges and the crush spacer that sits between the two bearings on the pinion.
Thanks, Martin.
Thanks, Martin.
