Electrical connectors
Posted: Thu Feb 17, 2011 8:46 pm
by redsmasher
I have a late 320 and need the connectors (male and female) for the injector loom. Is it possible to get these connectors with 'pigtail' short lengths of wire? Thank You.
Re: Electrical connectors
Posted: Fri Feb 18, 2011 3:08 pm
by Cotswoldbmw
a bit tricky this, on all the new models if you look at the injector picture it shows the block connector and wires that plug into it nice and simple, on the old models it shows the block connector but not the wires/pins it shows these on a different section, this section has all the electrical pins for the whole car in one place with no discriptions only measurements, if you send me your email i can send you a picture as an example but i would suggest the best bet would be visit your local dealer and see if they can identify the one you need, if you need any more help let me know
Brett
