Steering parts please
Posted: Fri May 29, 2009 5:15 pm
by SHAZ1
http://www.realoem.com/bmw/showparts.do ... g=32&fg=20
Parts: 6,8,9,10,13
Not sure of the availability.
the problem is there seems to be a small leak at that connection, hope these parts will fix that.
Price with postage to W2 London area please.
Re: Steering parts please
Posted: Tue Jun 02, 2009 4:22 pm
by Cotswoldbmw
Hi there
as you can see from real oem differant numbers depending on age, can i please have chassis number
Brett
Posted: Wed Jun 03, 2009 11:15 am
by SHAZ1
Hi,
Thanks will forward the info via PM this evening if thats ok and also want to add the sump gasket to the order and also is there anything else you would recommend changing while changing the sump gasket?
Shaz
Posted: Fri Jun 05, 2009 11:40 am
by SHAZ1
PM SENT
Posted: Fri Jun 05, 2009 12:49 pm
by Cotswoldbmw
Morning
No 6 £29.29
Says for yours you dont have 8,9,10 do you def have that fitting on the end
No 13 £1.15 each
Sump Gasket £8.74
F-Anti roll bar links,brackets and nuts x2 of each £64.89
R-Anto roll bar links,brackets and nuts x2 of each £27.31 inc
Ref No 49232
All prices inc vat,discount and delivery to minland uk
Regards Karl
Posted: Mon Sep 14, 2009 1:46 pm
by SHAZ1
Sorry for the long delay, car was off road due to other engagements.
but i still require the above parts except the anti roll bar parts,
No 6 £29.29
"Says for yours you dont have 8,9,10 do you def have that fitting on the end" (YES, INCLUDING THESE PLEASE)
No 13 £1.15 each
Sump Gasket £8.74
can i also add an ICV? and
full service kit ie; spark plugs filters etc...
sorry not sure what its called so will attempt to describe it, the drive shaft seals for the diff its the shafts that connect to each side of the diff ie; if your looking at the vehicle from the rear the left and right side of the diff as there seems to be a slight leak from the right side
also the seal where the prop connects to the gear box as there also seems to be a small leak, please contact me if you need the above requests clarified
Can you please give me total price posted to london W2
I can send the chassis number again if needed
Posted: Thu Sep 17, 2009 11:05 am
by SHAZ1
bump
Posted: Mon Sep 21, 2009 11:04 am
by Cotswoldbmw
Hi There
sorry for the delay can i get chassis number again
Brett
Posted: Wed Sep 23, 2009 12:28 am
by SHAZ1
pm sent
Posted: Thu Sep 24, 2009 7:40 pm
by SHAZ1
bump
Posted: Tue Sep 29, 2009 12:54 pm
by SHAZ1
BUMP
pm sent
