strugling to find parts
- hammersfan12
looking for the brake servo pipe with return valve that goes from servo to the inlet manifold, and the metal tube with the spring that goes from the case to the inlet manifold, think it's a breather pipe. thanks
- hammersfan12
the pipe is the oil return one.
- Brianmoooore
You'll need to state at least the type and year of your engine. If all is original, the last seven digits of your VIN is what's needed.
- hammersfan12
i always forget that, it's a 91(h) reg m20 325, i'll get the vin aswell.
- hammersfan12
AE54822
- Cotswoldbmw
- Contact:
Hi there
i have had a look and am not sure which ones you rtequire, the best thing to do is have a look at realoem.com
this uses the same pictures as us so you might be able to id which you need
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
