VRD\\ Superflex poly bushes
Posted: Thu Sep 15, 2011 12:11 pm
Front Lower Arm Rear Kit of 2 60.5mm OD Bonded Outer Shell Bushes, Standard Caster, Competition Style Heavy Duty. SF094-1457-80K £83
Front Lower Arm Rear Kit of 2 60.5mm OD Bonded Outer Shell Bushes, Eccentric M3, Competition Style Heavy Duty. SF094-1459-80K £83
Front Anti Roll Bar Mount to Chassis Kit of 2 (flat base) Bushes, replaces OEM# 31.35.1.129.159 (ARB diameter required). SF093-0358K £21
Front Anti Roll Bar Link Eye Kit of 2 Bushes & 2 Stainless Steel Tubes. SF093-1862KSS £32
Rear Trailing Arm Standard Kit of 4 Offset Flange Cotton Reel Bushes & 4 Stainless Steel Tubes, replaces OEM# 33 32 9 061 945. SF093-1754KSS £52
R Trailing Arm Kit 4 offset Flange Bushes, 4 Camber & Toe Adjustable Threaded 2.75mm offset Stainless Steel Tubes & 4 Camber Adjusting Bolts for easy adjustment. SF093-1754CKSS £134
Rear Anti Roll Bar Mount to Chassis Kit of 2 Bushes (ARB diameter required). SF093-0341K £15
As usual, any quesions please feel free to ask. Post here or email us at info @ visionracingdevelopments.co.uk
Sponsorship opportunities available
ORDERING
To place an order simply send us an email to info @ visionracingdevelopments.co.uk with the parts you'd like to order. We will then send you an invoice, you pay, we send the items, happy days!
Payment is accepted via Paypal or cheque. Cheques will require time to clear before we can go ahead and post anything out.
If you have any quesitons please feel free to ask!
ORDERING
