E36 Rear Wishbone
Posted: Sun Aug 19, 2007 10:11 pm
by james_obryan
Basically my balljoint/bush at either end of the e36 rear lower control arm has been busted as its worn out or broke when adjusting the now un-seized arm.
Is it easy to fit a replacement balljoint near the hub, or do you need a press?
What about the bushing near the diff. carrier?
Re: E36 Rear Wishbone
Posted: Sun Aug 19, 2007 11:53 pm
by Kos
you thought about posting on e36coupe.com ??
Posted: Mon Aug 20, 2007 11:18 pm
by Zerotonine
I'm sure someone on here will know, I haven't had any problems with mine like that touch wood
Posted: Tue Aug 21, 2007 10:18 pm
by romario
My E36 had a knackered wheel bearing and because i drove several thousand miles with it rumbling the garage were unable to remove the bearing. They ended up sourcing a used hub from a scapyard. To fit just the wheel bearing a press is needed, not all garages have these. I got quotes of £90 upwards for 1 wheel bearing and fitting.
