MiM Alloys
Posted: Fri Nov 24, 2006 2:44 pm
by Pal318is
Can anyone get some pic's up of some MiM Alloys pls, as my searching has got me nowhere :? older one's if possible.
Respek
Pal
Re: MiM Alloys
Posted: Fri Nov 24, 2006 2:49 pm
by E30BeemerLad
do a google for MIM 1900, should bring something up mate
Re: MiM Alloys
Posted: Fri Nov 24, 2006 3:08 pm
by Ziggy
:thumb:
Re: MiM Alloys
Posted: Fri Nov 24, 2006 3:33 pm
by ed325i
Re: MiM Alloys
Posted: Fri Nov 24, 2006 6:19 pm
by baur320
I've just won a set off ebay.
Just been told that some were made by other firms. Mine are stamped Made in England on the back, so they might not be original. They have painted spokes, polished rims.
Cheers,
Mick
Re: MiM Alloys
Posted: Fri Nov 24, 2006 6:24 pm
by StuBeeDoo
Re: MiM Alloys
Posted: Fri Nov 24, 2006 6:31 pm
by ed325i
essbee wrote:Image
Where did you get the centre caps ?
Posted: Fri Nov 24, 2006 6:36 pm
by e30symphony
As above, Im looking for a set of centers with ages now.
Re: MiM Alloys
Posted: Fri Nov 24, 2006 6:42 pm
by StuBeeDoo
ed325i wrote:Where did you get the centre caps ?
I went to a local tyre place. They had loads of new and used centre caps of all different sizes and shapes. They charged me £1.00 each, IIRC.
I struck lucky, because 58mm is an odd size, they told me.
They aren't MiM caps and they don't quite fit properly. They had a stuck-on logo. I took the logos off and sprayed the caps the same colour as the wheels.
I haven't got any yet, but there are genuine BMW roundels that should fit.
Re: MiM Alloys
Posted: Fri Nov 24, 2006 7:29 pm
by ed325i
How do they fit ? Do you know what they where off ?
Re: MiM Alloys
Posted: Fri Nov 24, 2006 7:33 pm
by StuBeeDoo
ed325i wrote:How do they fit ? Do you know what they where off ?
Sorry Ed, I can't remember now. It was a brand of wheel I don't recall having heard of. I'm trying to think what the logo was.....
They are push-fit. IIRC, they have 4 spring lugs on each cap.
Posted: Fri Nov 24, 2006 7:54 pm
by baur320
e30symphony wrote:As above, Im looking for a set of centers with ages now.
Any idea if E32/34/36 parts fit?
Posted: Fri Nov 24, 2006 8:09 pm
by StuBeeDoo
baur320 wrote:Any idea if E32/34/36 parts fit?
Don't think so Mick. AFAIK, the 5-stud BMWs use 65mm caps.
Re:
Posted: Fri Nov 24, 2006 8:13 pm
by baur320
So I can't pinch Barbara's??? winkeye
Re:
Posted: Sat Nov 25, 2006 1:57 am
by Pal318is
Thanks for all the replies guys...but the alloys i'm looking for are a 5 spoke MiM wheel...as opposed to the multi spoke ones that have been posted...
Thanks Again
Pal
Re:
Posted: Tue Nov 28, 2006 7:46 pm
by baur320
Been to essbee's local tyre place with my one and only centre cap.
After much rooting around in the back, they found that Alessio centre caps are the exact diameter, although the clips are different. Bought the last four for £2 each, took them home and they fit fine - although they rattle slightly. This weekend I'll spend a bit of time trying to get them tighter, painted, badges fitted and let you know how they've worked out.
Cheers,
Mick
Re: MiM Alloys
Posted: Tue Nov 28, 2006 7:52 pm
by 316vinni
baur320 wrote:I've just won a set off ebay.
Cheers,
Mick
Thats the same as mine :D
Posted: Tue Nov 28, 2006 7:55 pm
by StuBeeDoo
Glad you've got sorted Mick.
The BMW 58mm badges are 36 13 1 181 081 if you want to have a go at them. May be worth having a word with Steve(?) at Mill - perhaps he could get you one on appro to check for size.
I'm still undecided, I quite like the look of mine as they are.
Stuart.
Re:
Posted: Tue Nov 28, 2006 7:58 pm
by liam012
are they badges or centre caps esbee?
Posted: Tue Nov 28, 2006 9:05 pm
by StuBeeDoo
They're badges Liam.
Re:
Posted: Wed Nov 29, 2006 5:57 pm
by liam012
Re:
Posted: Wed Nov 29, 2006 6:14 pm
by StuBeeDoo
liam012 wrote: possible?
Definately the right diameter. Don't know about the length of the legs though. They may have the same problem as Mick (Baur320)'s got with his.
I doubt you'll find anything that will be a perfect fit though. Compromise is better than no centre caps at all. Just need a bit of ingenuity to keep them tight in the rim.
Re:
Posted: Sat Dec 09, 2006 11:50 am
by baur320
Right, I've rubbed down the Alessio centre caps to get the chrome effect off, sprayed them silver and got some badges. They look fine.
To stop the rattling, I've fitted the centre caps to the wheels. From the rear of the wheels and through the centre hole, I've forced a 2 inch piece of insulated wire between the claws of the centre cap and the wheel. The insulation compressed and holds the centre caps tight. It sounds a bit of a bodge job, but so far they're solid.
If I can suss out how to post pics (imageshack loads too slow), I'll get some up this weekend.
Cheers,
Mick
Re:
Posted: Sat Dec 09, 2006 1:13 pm
by StuBeeDoo
baur320 wrote:If I can suss out how to post pics (imageshack loads too slow), I'll get some up this weekend.
Mick, if you can e-mail them to me, I'll host them for you.
