Aparent miss-fire
Posted: Mon Apr 13, 2015 9:06 pm
by martauto
318ti 1998 185k
She starts up and runs fine but try and put it under load and it chugs just like a miss-fire.
No water loss and oil ok, temperature fine as well.
I took no1 lead off and clear water came out , not a great deal but it was there. I dried it off quickly and it still ran the same.
Any ideas please?
Re: Aparent miss-fire
Posted: Tue Apr 14, 2015 3:20 pm
by Andyboy
Remove and clean up all of the rubber boots for the plugs and coils. The plugs are normally about 1000 years old on most E36's.
Posted: Wed Apr 22, 2015 5:45 pm
by martauto
What do you suggest I replace them with?
Posted: Thu Apr 23, 2015 7:05 pm
by jimmyspeed
hey mart
I sold you a ccv and sent a few other bits from my troublesome m44 a while back, i went through the leads on mine too. You can check their resistance before swapping as they may be OK. I found the resistance value online, and firstly changed 1 lead , then i fitted a new set - it made no difference!
another thing to check might be a loose CAT in your exhaust, mine broke of and would restrict the car to 40mph
also worth cleaning the idle valve as this used to give me issues, did i sent you mine?
Posted: Fri Apr 24, 2015 5:16 pm
by martauto
Hi mate, Thanks for the reply.
I took a punt and bought a second hand coil pack and set of leads (£30) and popped them on last night and all seems to be well.
Many thanks guy`s.
