E36 Steering
Posted: Thu Jul 24, 2014 5:38 pm
by Nobby_N
I lent a friend the 316i compact beast and he's rang me saying the power steering keeps going stiff then normal every now and again! Fluid levels ok so when he brings it back what should I look for on it!
Re: E36 Steering
Posted: Thu Jul 31, 2014 8:47 pm
by Nobby_N
Got the car back and can't see any leaks on the rack or connections, fluids look to be at perfect levels, any ideas, are pumps hard to replace
Re: E36 Steering
Posted: Thu Jul 31, 2014 9:48 pm
by sweep
pumps not hard to fit,is the belt ok?
Re: E36 Steering
Posted: Thu Jul 31, 2014 10:55 pm
by CaesarBob
Check the top of the steering column, under the bonnet just where it comes out the firewall. My old E36 had what looked like a spring there which was a bit corroded. Lashings of WD40 over a couple of days freed it right off.
Google searches throw up a few threads, seems to be more common problem over the Pond. Symptoms were uneven weighting and a notchiness or random stiffness when manoeuvring.
Re: E36 Steering
Posted: Fri Aug 01, 2014 8:45 am
by Nobby_N
ganna have a look at the joint Bob, I googled it last night and symptoms are same so hopefully some lube action will fix as belt looks good! Cheers
Re: E36 Steering
Posted: Sat Aug 09, 2014 10:54 am
by CaesarBob
Did you sort this Nobby?
