Really odd E46 320d temp guage issue
Posted: Thu Jan 24, 2013 6:16 pm
My car doesn't overheat, but I have an issue with the temp guage on long journeys. Sits bang in the middle for about two hours, then starts to creep up. When switched off, the guage only drops back "half a guage" to rest. ie if it has gone up to register 3/4, when switched off the needle only goes back to 1/4 not right back to the left. I use live temp reading on the OBC, the water temp sits a few degrees either side of 80, the car definitely isn't running any hotter when the guage rises. And it only happens after about two hours constant driving, any less and it sits bang in the middle. Driving steady or harder, back roads or motorway makes no difference, always happens about two hours into a drive. When left a while (hours, not minutes) the resting position moves back to where it should be. Anybody ever come across anything similar?
