E39 issue...
Posted: Tue Oct 05, 2010 10:18 pm
by ImysE30
Hoping someone can help or provide some info/give some advice.
E39 528i Sport (2000 W). Starts up and drives fine in the morning. Come lunch time, the car starts up but hesitates, when putting foot down there is no pick-up, it feels dead? It doesn't do this in the morning?
Have changed the Air Mass Sensor thingy with a new one from BMW (£200) but has not made any difference.
Any ideas on what else to check?
TIA
Re: E39 issue...
Posted: Wed Oct 06, 2010 4:09 pm
by Jon_Bmw
Read the codes before changing things?
Might be a cam sensor, but I really would get the codes read. Being an e39, you'll have to sift through hundreds if it hasn't been read in a while.
The diagnostics is almost too clever for its own good.
Re: E39 issue...
Posted: Wed Oct 06, 2010 6:34 pm
by bss325i
Most likely a failing cam sensor or an air leak on the intake side but as said, get the fault memory read first.
Re: E39 issue...
Posted: Wed Oct 06, 2010 9:01 pm
by ImysE30
Diagnostics has been done, mates car not mine. Came up with air mass sensor faulty so he's changed that but still no improvement
Re: E39 issue...
Posted: Wed Oct 06, 2010 9:10 pm
by bss325i
Were the adaptions reset after the mass sensor was replaced?
Was it a genuine BMW, OE quality or chineese mass?
Also check for air leaks.
Re: E39 issue...
Posted: Wed Oct 06, 2010 9:33 pm
by ImysE30
Ermm not sure on that one, i'll ask him.
Genuine one from BMW, over £200.
Will check.
e39 engine
Posted: Sun Oct 10, 2010 9:24 pm
by ruja98
This sort of thing has happened twice on my 528. Car would start fine when cold, then when it got up to temp would go sluggish and stall sometimes, was the crank sensor both times.(two separate engines) Hope this helps
Re: e39 engine
Posted: Mon Oct 11, 2010 2:19 pm
by ImysE30
Will get that checked too, cheers
Re: e39 engine
Posted: Fri Oct 22, 2010 11:37 am
by ImysE30
Managed to get it back on the diagnostic's, turned out to be the 'Inlet Camshaft Sensor' and 2 of the inlet pipes.
Thanks for the help
Re: E39 issue...
Posted: Fri Oct 22, 2010 1:11 pm
by Jon_Bmw
bss325i wrote:Most likely a failing cam sensor or an air leak on the intake side but as said, get the fault memory read first.
Who needs a fault code reader when Barry is around.
Re: E39 issue...
Posted: Fri Oct 22, 2010 8:11 pm
by bss325i
Excelent!
Problem solved.
Re: E39 issue...
Posted: Fri Oct 22, 2010 8:16 pm
by ImysE30
Yep, thanks
Re: E39 issue...
Posted: Fri Oct 22, 2010 8:32 pm
by bss325i
No worries.
