what pads for porter cable and zaino?
Posted: Tue May 29, 2007 10:56 am
by liam012
Just ordered a porter cable but i am unsure which pads to use -
i will be using zaino "z-AIO" and z5.
someone has suggested applying with the blue sfx pads at low speeds only.
is this correct?
Re: what pads for porter cable and zaino?
Posted: Tue May 29, 2007 2:12 pm
by m3ben05
Im looking at the sonus pads, they do a whole kit for $60 in the states. Iv PM'd C76JON about it, once i get a reply il let you know his recomendations
Posted: Tue May 29, 2007 6:15 pm
by pete323
Go for the LCC Pads from polished bliss
The Sonus pads are rubbish
Posted: Wed May 30, 2007 9:00 am
by c76jon
pm replied to
unfair to say the sonus pads are rubbish
lake country are imho the best...........they are what i have found to work best for me
but sonus are far from rubbish .what products are you using /did use with the sonus??
jon
Posted: Wed May 30, 2007 10:16 am
by liam012
Jon
I'd really appreciate your advice as this will be my first detail with a pc and with zaino.
the products i am getting are:
z7
Z-aio
z5pro+Zfx
Z8
Zcs
But i have a few questions!!
1) Will i need Z6 as a qd spray between z-aio and z5 and each subsequent coat of z5? or maybe the z8 will do?
2) Only Z5 and i presume Z-aio will be applied with the pc - but with which lake country pad? the finishing pad?
3) will i notice a difference between one coat and 3 coats of z5???
4) what is the best type of cloth/towel to remove products after each application?
5) will i survive with a 6" pc applicators only for a while? (the zaino is cleaning me out!!)
6)maybe there is no need for the z8 as i am getting the zcs perhaps i would be better off getting the z6 for in between coats.?
i think thats it! cheers!!
Posted: Wed May 30, 2007 10:25 am
by c76jon
liam012 wrote:Jon
z7
Z-aio
z5pro+Zfx
Z8
Zcs
use the z8 .thats what ido
porter is used to prep paint remove defects etc and application of z aio and z5
yes yes yes
topquality m/f towels
clarify dont fully understand question
z8 is amazing zcs first then z8 after and use after subsequent washing
Posted: Wed May 30, 2007 10:27 am
by boxclever1753
got to say that lake country pads have been the best for me too... and they are colour coded so you know which one to use for which step..
Posted: Wed May 30, 2007 10:28 am
by boxclever1753
i'm beginning to think that liam and jon work for zaino or for one of those advertainment channels....
Posted: Wed May 30, 2007 11:47 am
by liam012
sorry i meant 6" pads for the porter cable - i dont think i can stretch to a set of 4" as wel.
there are different lake county pads for different abbraisaveness's (sp!) as the zaino is not abbraisive at all will it all be applied by the same grade pad or should i get different grade pads for the z-aio and the z5??
after my rambling below i have just realised that the car has not yet been properly polished since the bare metal respray. i guess thats the cause of the slightly unshinny lack lustre appearance - dont get me wron it is clean and the paint is 'good' no scratches or swirls really but its just a bit dull - does that make any sense?? would you reccomend something prior to the z-aio and after the z7 and clay thats a bit more abbraisave??
@boxclever1753 no mate! no advertising - i have however purchased an absolutely mint resprayed shell. it is like new and i want to keep it as well protected as possible as i know i will never have a shell in this condition again. also its lachs silver and the first time i meguiars it by hand i had trouble getting a "bling" finish of it as i dont know is it just me or is lachs silver quite a dull colour (as opposed to how black cars come out when they are detailed). maybe as it was only sprayed a few months ago it was never "properly polished" i am thinking aloud now, mmm brings me on to question 3....
Posted: Sun Jun 03, 2007 3:59 pm
by 325iSportMark
Sorry if this is slightly :offtopic: but I've noticed a lot of people talking on here about porter cables, are they a special kind of buffer? If so what is different about them?
I've been using a buffer for years, and always swear by them to get ultimate results so long as you know what you are doing. My current one is a Felisatti a variable speed, using 3M pads, which I find works really well, if a little heavy.
So back to the question, are they special, or is it just that they are a particularly popular/cheap/easy to use buffer. Don't think for a second that I am doubting them in a "mine's better than yours" kind of way, I've never seen one so I am just trying to find out what the fuss is all about. :cheers:
Re:
Posted: Thu Jun 07, 2007 10:06 pm
by Frenchy
Mark,
A lot of serious car detailers use them as the only way you will damage your paint with one is by dropping it on your car.
Unlike say a 9" grinder with a buffing pad as used by many bodyshops if not careful they will burn the paint off and can cause a lot of damage they were specifically designed for polishing without damage the weight of the machine does most of the work.
Made in USA nd 110v operation at present so you need a step down transformer they are a Random Orbital polisher ie;do not spin concentrcily and as such move around on their axis and as such can do many times the work elbow grease can do in a few minutes.
Check out Cargeeks.co.uk
Re:
Posted: Fri Jun 08, 2007 8:46 pm
by 325iSportMark
Frenchy wrote:Mark,
Ah ha, now I understand, thanks for explaining it :cheers:
You're absolutely right about the big orbital buffers like mine, if you're not careful you can really wreck your paint. I suppose I'm just lucky that when I was learning how to use them it was on other peoples cars when I used to work as a valeter winkeye so now i feel completely confident to use it on my own car. The key is to make sure you spray plenty ofwater if you're using a strongish compound like Farecla G4, keep a close watch on the temperature of the panel and always keep the mop moving
Re:
Posted: Fri Jun 08, 2007 9:03 pm
by Frenchy
The porter will not shift as many deep marks as an orbital buffer that you are used to,a big buffer (fnar fnar) and G4 Compound can cause a lot of damage in the wrong hands,whereas the porter is quite harmless. winkeye
