Loose dechromed trim on drivers side
Posted: Thu Aug 10, 2006 8:58 pm
by eldarvanyar
The dechromed trim that runs across the roof and down the drivers piller has come loose. I've got some sellotape holding it down at the moment. Any ideas as to how to fix it, is there a special sealent / adhesive to use or do I need new trim?
Re: Loose dechromed trim on drivers side
Posted: Thu Aug 10, 2006 9:06 pm
by smithy318i
glue
Posted: Thu Aug 10, 2006 9:09 pm
by eko
Blob of araldite(or similar) and it wont be going anywhere
Posted: Thu Aug 10, 2006 9:20 pm
by Chris-W
Or pinch the two attaching strips together slightly.
Posted: Thu Aug 10, 2006 9:24 pm
by SCOTT325SE
you can PROBABLY remove it and pinch the stuff so it grabs tighter, but ive got a complete dechrome kit that im selling if you wanted a new set. Try the pinch method 1st though for cheapness of solution
Posted: Thu Aug 10, 2006 9:26 pm
by eldarvanyar
Thanks guys wanted to check with the experts first,
