Microfibre and other stuff left overs
Posted: Fri Feb 03, 2006 8:27 pm
hi all
Firstly a big thankyou to all that bought cloths from me
there were a lot of people tho that ordered from here and bmwcc that never got back in touch or havent paid and therefore there is a quantity still available plus some other stuff people have asked for
so heres what is available and prices
all this lot are top top quality.any questions then please ask.
waffle weave drying towels Ԛ£13
ultra plush zaino approved microfibre towels for buffing Ԛ£5
microfibre wash mitt Ԛ£8.50
microfibre polish/product applicator Ԛ£2.50
all above are machine washable and pictures can be seen on previous group buy thread
NEW STUFF
microfibre glass cloths very tight weave microfibre cloth that will not leave lint on glass and leaves glass smear free Ԛ£4.50
Tyre shine applicators shaped sponge applicators that allow very precise application of your favourite product.Note these are made of 2 types of sponge.the handle part is a non absorbant type which is stiff and application surface is absorbant.this prevents you getting covered in the stuff and not wasting product .Ialso use one of these to apply things like plastic trim and rubber products like 303 protectorant as you can be very precise without covering paintwork when doing door trims and bumpers,grills etc
2 applicators Ԛ£5 (limited Supply!!!!)
Porter cable orbital pad sets 3 pads of the highest quality in 3 different grades a yellow coarse pad for heavy swirl removal,a white pad for polishing and removing light swirls and marring and finally a non abrasive pad for application of polish/wax 3 pads Ԛ£29
Microfibre wash/buffing mitt this mitt is only just been made available and i have been testing it for a month.A new type of pile that is the softest i have ever seen.very very efeective as a wash mitt and amazing at removing hazed polish/wax from panels.quality of this is amazing.
thumb has been removed so you can use both sides ie two washing removing surfaces with a quick spin.
Ԛ£9.50
High performance microfibre towel
It is a "Chennile MicroFiber Towel" with over TWICE the fibers per square
inch (a whopping 4,000,000), it has an extremely tight weave, greater
density (you can feel the weight)extremely durable and the most advanced
design available, over 2x the amount of the fibers are split (
a machine was specially set up and designed for this towel..., a lot of R&D went
into this:)
It is designed for very delicate finishes, show cars, collectors and other
valuables that need and deserve the Very Best(you will not feel the "snags"
on your fingers like conventional MicroFiber)as it is not only very gentle
and soft, but also very high performance, removing stubborn polishes and
waxes without having to use as much pressure to clean, which translates into
less chance of any marring, swirls, scratches, etc. Ԛ£6
as always none of these will mark your paint in any way and there are no labels attatched to cause scratches.
also notice that the newer towels are moving towards lighter colours so if you were to pick up any debris under the towel you would see it a lot easier and therefore potentially prevent damage sooner
truly the best out there.
john
NEW STUFF
Ԛ£9.50
into this:)
john
