Headliber colour change
Posted: Sun Feb 10, 2013 11:05 am
by GAZZANATOR
Lokking for a little advice on what to do with a stained and rather nasty looking headliner.I thought about masking it off and spraying it black with a fabric dye,but not sure if this will work.I've read these are an absolute pain to take out or I'd just have a new one made and replace it.I've tried all the usual fabric cleaners and nothing works
Re: Headliber colour change
Posted: Sun Feb 10, 2013 11:07 am
by Cloggy Saint
Touring or saloon?
Posted: Sun Feb 10, 2013 7:17 pm
by GAZZANATOR
Sorry,It's a touring.
Posted: Sun Feb 10, 2013 7:31 pm
by Cloggy Saint
They're not so hard to take out. just takes a bit of time. If you remove it then it's a simple job to cover it with the material of your choice.
Inspiration, but made easier by not having a sunroof :)
Posted: Sun Feb 10, 2013 7:47 pm
by GAZZANATOR
I read somewhere you had to take out the windows and all sorts.Is it a rigid headliner in the Later model E30s then ?
Posted: Sun Feb 10, 2013 9:06 pm
by Cloggy Saint
It's just saloons that need the front and rear screens removed. The touring has a rigid headlining.
Posted: Mon Feb 11, 2013 7:46 pm
by GAZZANATOR
So,I just remove the trim,unscrew grab handles/mirror etc,and it should lift out ?
Unfortunately I do have a sunroof,but I feel a little more confident at tackling it now.Thank you :thumb:
Posted: Mon Feb 11, 2013 7:53 pm
by Cloggy Saint
It's not just the interior fittings that keep it up. There are also a couple of clips under the raised area in the middle and some more around the tailgate hinges. Release the rear clips first (these are obvious to see) and then to release the centre clips you need to give the headling a sharp tug backwards. This is best done with 2 people.
