polishing
Posted: Tue Apr 24, 2012 2:04 pm
by jimmypee
If i were going to machine polish a car using maguires compound do you need to use water with it or does it self lubricate
Re: polishing
Posted: Tue Apr 24, 2012 2:29 pm
by Rav335uk
LOADS OF WATER!!!!
Re: polishing
Posted: Wed Apr 25, 2012 9:15 am
by twoscoops
depends on what compound you are talking about from Meguiars, 105, 205, D300???
Re: polishing
Posted: Wed Apr 25, 2012 7:51 pm
by e30den
jimmypee wrote:If i were going to machine polish a car using maguires compound do you need to use water with it or does it self lubricate
No water is needed at all :)
Re: polishing
Posted: Wed Apr 25, 2012 10:02 pm
by Mike-
Never used any water with a machine polish, bit of spray on the pad before you start and job done.
Re: polishing
Posted: Thu Apr 26, 2012 11:00 am
by twoscoops
yip i agree. A spritz of water to prime the pad and then you the correct polishes.
Posted: Thu Apr 26, 2012 11:12 am
by jimmypee
cheers
Re:
Posted: Thu Apr 26, 2012 7:14 pm
by Kos
with the older type compounds water was needed but with the modern stuff its not required. i is handy to have some close by to cool down the panel if it gets too warm
Re:
Posted: Fri May 04, 2012 12:54 pm
by m8782538
I use megs 105 and 205 and they are fine to use as they are, just prime your pad as normal and you will be ok.
