what colour waxoil
Posted: Mon Jun 15, 2009 11:46 pm
by bodger
im going to be waxoiling the underside of my car soon with a proper waxoil gun and compressor, i thought about using the black one to make it look tidy underneath but this now seems to me that it may look like im trying to hide a multitude of sins which im not. so do i use the clear stuff or black
Re: what colour waxoil
Posted: Mon Jun 15, 2009 11:52 pm
by Sanchez
Black will look better.
Clear and you'll be able to see whats going on with the rust.
Posted: Tue Jun 16, 2009 12:15 am
by A1BMW325iSport
well if you know all the metal is sound just go for the black
Posted: Fri Jun 19, 2009 12:03 am
by leeparkes
bodger wrote:this now seems to me that it may look like im trying to hide a multitude of sins which im not.
As proof take photos before you waxoil it.
Id go black too.
Posted: Fri Jun 19, 2009 12:08 am
by Speedtouch
On a light coloured car, I'd go for the clear stuff as black will stain badly if you accidentally overspray it, and the stuff tends to run all over the place in hot weather so could make a mess of your driveway too.
Posted: Fri Jun 19, 2009 8:04 pm
by bodger
cheers everyone
Posted: Fri Jun 19, 2009 8:07 pm
by sweep
Mine is black bodger and i put a full tin on the underside every year,empty a old schults can,clean it out with thiners/petrol,then fill the can with wax oil and spray the underside till its running off.
by fuzzy
i went for black on mine. makes it look much nicer than clear on wire brushed flaky paint bits.unless your car is showroom underneath?
Posted: Fri Jun 19, 2009 8:32 pm
by bodger
black it is, cheers everyone, the cars not mint underneath but even so i think i'll use the black, it should look good with the new beam, tank and all new brake and fuel pipes
Posted: Fri Jun 19, 2009 8:40 pm
by fuzzy
i think i overdone mine, i used a 2.5 litre can and a 5 litre can .
Posted: Fri Jun 19, 2009 8:42 pm
by sweep
Do the behind the inner wheel arch trims too.
Posted: Fri Jun 19, 2009 8:44 pm
by fuzzy
i stripped everything out to get a better coat under everything, exhaust,gearbox,diff,prop,plastic inner arches etc and also removed my tech2 cills to coat under them. should last a while now.
Posted: Fri Jun 19, 2009 9:16 pm
by B7
Personally I'd go clear. The blacks an absolute nightmare when your working on it. The guy who had mine before me absolutely caked the thing in it and it looked shit and you couldn't touch a thing without getting covered. I stripped the lot off and started again!
Just a light smattering of clear in all the right places is all thats needed.
