Foam Gun
rob750
Sun Feb 18, 2007 3:37 pm
What do people think of the foam gun attachments ? Are they compatible with ZAINO products ?
Regards
Rob
c76jon
Sun Feb 18, 2007 5:02 pm
ive used one with z7 in it
personally if iam using zaino products i wouldnt mix and match with other soaps
it foamed ok but not aswell as if u use some of the products designed to be used in these guns
its a good form of presoak for dirty cars to remove bulk of shyte
still going to have to wash it tho
jon
ShineOn
Mon Feb 19, 2007 10:13 am
Foam guns are good, as Jon says specifically if the car is properly dirty. The foam clings and soaks some of the dirt off, give it a rinse, then wash it properly using the two bucket/grit guards/wash mits and you'll do a good job of not scrubbing dirt into the paint.
