how to fit m tech 2 side pods/skirts?
Posted: Wed Jan 30, 2008 12:27 pm
by snoops
can anyone tell me how to fit m tech 2 side pods/skirts?
Re: how to fit m tech 2 side pods/skirts?
Posted: Wed Jan 30, 2008 3:44 pm
by aceraf
If anyone has a guide for fitting the kit then i could use a copy aswell.
I think if there is one out there then it should probably be made a Sticky as i'm sure there's plenty demand for it.
Posted: Wed Jan 30, 2008 4:22 pm
by abelai
I believe there are templates that you can still buy from BMW that stick to the car and you drill accordingly. You can see them on realoem
Posted: Wed Jan 30, 2008 4:27 pm
by aceraf
abelai wrote:I believe there are templates that you can still buy from BMW that stick to the car and you drill accordingly. You can see them on realoem
I can get to this
http://www.realoem.com/bmw/showparts.do ... g=51&fg=95
but it doesn't give you any guide's there. Just lists part numbers.
Posted: Thu Jan 31, 2008 8:31 am
by abelai
No not there. Here:
http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
If you go to your dealership and ask some parts have fitting instructions, be nice and they might print them off. I'm collecting some parts on friday I shall ask.
Posted: Mon Aug 11, 2008 3:51 pm
by jon_d_h
Im also stuck with fitting the side skirts and side pods. I dont know where to start with them. Have any off you had any luck?
Posted: Fri Aug 29, 2008 8:07 pm
by corkie
me to iput this up before and got nowhere,it must be top secret lol.
Posted: Sun Aug 31, 2008 9:59 pm
by gazza
lads pm me a email address and ill try and send the original bmw instructions (in pdf format) you can buy the template but its about £20 to. but then chuck it after use ...i fitted mine without it just make sure you buy all the correct clips its not as hard as you think i used one of the clips with the 2 pins removed as a guide for the drill and lined the sill up and marked it it dont have to be perfect as there is a bit of leeway on the sill for the clip to move
Posted: Tue Sep 02, 2008 5:50 pm
by corkie
you have pm
Posted: Tue Sep 02, 2008 5:52 pm
by gooner1
Sorry to jump in, but is there one available for the Zender skirts?
Posted: Sun Sep 07, 2008 10:02 am
by corkie
bump winkeye
Posted: Sun Sep 07, 2008 11:25 pm
by 2_stroke
gooner1 wrote:Sorry to jump in, but is there one available for the Zender skirts?
i have the best fitting kit for zenders you can get it in b&q its called no nails :mad:
Posted: Mon Sep 22, 2008 1:07 pm
by jon_d_h
I am now half way through fitting the side skirts and pods but have had to stop as BMW sent me the wrong clips :-x . I have been taking pics through doing it so will make a thread on how to do it when im finished as I found it hard to get infomation on this topic.
Posted: Thu Sep 25, 2008 8:47 pm
by scottidog
dont they just clip into the holes where the original rubbing strips go down the car, and clip on at the bottom.
Posted: Wed Dec 10, 2008 8:44 pm
by JamOnIt
Has anyone got a copy of the PDF file Gazza mentions in this thread?
Posted: Thu Dec 11, 2008 1:06 am
by cactusjacks1
gazza wrote:lads pm me a email address and ill try and send the original bmw instructions (in pdf format) you can buy the template but its about £20 to. but then chuck it after use ...i fitted mine without it just make sure you buy all the correct clips its not as hard as you think i used one of the clips with the 2 pins removed as a guide for the drill and lined the sill up and marked it it dont have to be perfect as there is a bit of leeway on the sill for the clip to move
You have PM
Posted: Thu Dec 11, 2008 1:07 am
by cactusjacks1
You have PM
Posted: Thu Dec 11, 2008 1:24 am
by Chase007
I want to know how easy is it to take it off with out mashing it up, plus once taking off is it best to buy all new fixings to go back on or just some certain bits? :)
Posted: Fri Jan 02, 2009 2:17 pm
by JamOnIt
the PDF for fitting the side pods (infact the whole kit) is mentioned and linked to at the beginning of mrlees front and rear fitting guide on the zone wiki.
http://rapidshare.com/files/147753716/M ... g.pdf.html
or copy and paste that into a new browser window and wait 45 secs.
I hope this helps you all and thanks mrlee for the info and great wiki article.
Posted: Sat Jan 10, 2009 1:02 pm
by mrLEE30
your welcome!
once i pull the tech 2 kit off of my sport (to send to the paint shop) i will update this wiki article to include the side pods.
mrlee
