wheels
Posted: Fri Aug 10, 2007 4:00 pm
by xstreamnetwork
hi guys i need your advice if you can. Im planning on getting new wheels for my car. i was planning on getting borbet b for it. but i needed to roll the arches so that it would not touch. but iv been told not to by the body shop as it will ruin the car???? so if i dont roll them what wheels should i get and if i roll them does it affect the cars hold (drive wise )???? :x
Re: wheels
Posted: Fri Aug 10, 2007 9:59 pm
by zaust
Not sure if it was the same wheel's, But Gigz has had his arches rolled, And it look's the nut's...
Re: wheels
Posted: Fri Aug 10, 2007 10:05 pm
by fuzzy
rolling the arches will only ruin the car if the arches are riddled with rust.id get a second opinion from a bodyshop that knows what they are doing then go for the borbets :wink:
Re: wheels
Posted: Sat Aug 11, 2007 12:23 am
by dips346
zaust wrote:Not sure if it was the same wheel's, But Gigz has had his arches rolled, And it look's the nut's...
he had them flared not the same as rolling
rolling only bends the return lip in so not to catch the tyres
Re: wheels
Posted: Sat Aug 11, 2007 1:47 am
by snoops
whats flared then?
Re: wheels
Posted: Sat Aug 11, 2007 2:07 am
by munky30
Flaring is when you take the flat part of the arch, the last inch or so before it ends. and flare it out so it follows the line of the rest of the arch.
Normal
flared
(and yes I know those aren't e30's)
Re: wheels
Posted: Sat Aug 11, 2007 11:12 am
by dips346
^^^^ what he said :)
Re: wheels
Posted: Sat Aug 11, 2007 12:22 pm
by munky30
Out of curiosity dips.. how much to flare the arcges on an e30?
I know its not quite as simple to do as I made out, needs some cutting and letting in of new metal...
Re: wheels
Posted: Sat Aug 11, 2007 1:25 pm
by dips346
munky30 wrote:Out of curiosity dips.. how much to flare the arcges on an e30?
depends on what size wheels you are putting on as rolling them can give the extra room
on the 2 tone tourer all we done was roll and pumped out the arch which i charge about £100 no painting needed
welding and cutting around £600 give or take
Re: wheels
Posted: Sat Aug 11, 2007 1:27 pm
by maxfield
Well that's save me a PM :)
Re: wheels
Posted: Sat Aug 11, 2007 1:40 pm
by munky30
16x9 all round spaced out 30mm at the rear and 5mm at the front, on a hefty drop...
Rolling wont cut it on the back, it will on the front but if the rears are done the fronts should be really, just for looks.
pumped out the arch?! :?
Re: wheels
Posted: Sat Aug 11, 2007 1:45 pm
by dips346
munky30 wrote:.
use the arch roller with a metal wheel and push the lip out about about 2"
Re: wheels
Posted: Sat Aug 11, 2007 5:03 pm
by kevster
Hi there guys, I'm new to all this, as I have an e24 635 but have just got a 1990 E30 318is. It's been lowered 60mm, which to my taste is far too much so I will be changing the springs so it's only lowered by 40mm. What I want to know is, will 17" Azev A's fit straight on or will it compromise the ride & handling too much ???Many thanks for any help! The Kevster.
Re: wheels
Posted: Sun Aug 12, 2007 6:27 pm
by xstreamnetwork
HI GUYS thanks for all the replys i dont want to flare the arches but just roll them to fit borbet b rims on them. i think it will need rolling at the back as my car is low at the back but if its tomuch work and will ruin my car then i will just get the car a bit higher at the back...
[/img]http://s149.photobucket.com/albums/s54/ ... 007207.jpg
Posted: Sun Aug 12, 2007 6:29 pm
by xstreamnetwork
Re: wheels
by dips346
where abouts are you
Posted: Sun Aug 12, 2007 6:31 pm
by xstreamnetwork
Re:
Posted: Sun Aug 12, 2007 9:27 pm
by Giggz
Flare them! winkeye They will look different on your cab to say the least. :D
Re: wheels
Posted: Sun Aug 12, 2007 9:44 pm
by fuzzy
kevster wrote:Hi there guys, I'm new to all this, as I have an e24 635 but have just got a 1990 E30 318is. It's been lowered 60mm, which to my taste is far too much so I will be changing the springs so it's only lowered by 40mm. What I want to know is, will 17" Azev A's fit straight on or will it compromise the ride & handling too much ???Many thanks for any help! The Kevster.
hello kevster. generally the thing to do is start your own new thread asking questions rather than jumping onto someone elses with an unrelated topic ,but 17" azevs should go straight on :thumb:
Re: wheels
Posted: Sun Aug 12, 2007 10:42 pm
by xstreamnetwork
in north london....
