Front Speaker Advice
Posted: Fri Apr 27, 2007 8:39 am
by Renton500
I need to swap the front speakers in my touring.
Can anyone recommend any coax speakers that will fit in the front? I don't want to spend a fortune and can't be bothered with components and tweeters etc, so i'm after just a straight swap into the original fittments.
I did try a pair of Kenwood Dual Mag's i've got, but they were too deep.
Someone recommended these to me, but i'm not sure?
http://caraudiosecurity.com/shop/produc ... /2851.html
Re: Front Speaker Advice
Posted: Fri Apr 27, 2007 1:09 pm
by andye30nut
infinity kappa 13cm speakers staright in no hassel great sound thts what ive got in mine mate :D
Posted: Fri Apr 27, 2007 2:11 pm
by iDreamBeemer
I plan to fit mine tomorrow but for exactly the same reason...easy to fit and good quality.
Once the full install is complete I am going to do a little write up from my experience, I hope it will be of use to people. I did some searching and I found the kapp for £59.99 + postage but the link is at home (and I am at work...)
Posted: Fri Apr 27, 2007 2:17 pm
by Morat
Is the original wiring up to it or did you replace it?
Posted: Fri Apr 27, 2007 2:21 pm
by iDreamBeemer
Is that to me or Renton? I (will) have 2 amps, 1 for sub and 1 for the other speakers.....
Posted: Sat Apr 28, 2007 1:09 am
by andye30nut
BASSJUNKIES.COM BEST PLACE TO GET THEM. :D
I POST PICS OF THE INSTALL THAT I STARTED IN THE 320I THEN RIPPED OUT
Posted: Sat Apr 28, 2007 1:19 am
by munky30
no point doing that unless you uprate the speaker wires.
shouldnt this be in the ice section?
Posted: Sat Apr 28, 2007 6:25 am
by ian332isport
munky30 wrote:shouldnt this be in the ice section?
Indeed it should :roll:
Posted: Sat Apr 28, 2007 12:52 pm
by chinchilla
Is it easy to do replacing speakers? i would like to do the same and dont want to get ripped off by ICE installers and there 'labour costs', i would like to replace the wiring as well with some chunky oxygen free wires.. and how do i get wiring to the rear panels in my cab? there is no speakers or wires!!
Posted: Fri May 11, 2007 1:31 pm
by connorb16
Just put infinitys in my fronts with new cable, sounds great and easy to fit. 8)
Posted: Fri May 11, 2007 7:32 pm
by aceraf
NEVER GO THERE!!!
they're a bunch of jokers.....i went there for a alternator swith charge relay, and the fools tried selling me a 0.5 farad power cap!!!
They also thought they could get 4 audiobahn subs (which need 3.5cuft each) into the boot of a nissan sunny,....when i had my back seats out to fit 4 15's that were in 1.9cuft boxes!!!
Biggest bunch of jokers i've seen!!! Even worse than MotorMax....
Mind you, not sure if it's the same people in other sites....the one i went to was in Derby, and i know they have other sites, but not sure if it's a franchise or the same people..!
