FITTING MTEC 2 BODYKIT
Posted: Fri Feb 09, 2007 10:36 pm
by jazzleeds
Hi
i,m in the process of fitting a mtec 2 kit on my 325i convertible. can someone tell me how the front lower valance is fixed on to the body. is there any clips that hold it together. i cant figure it out.
please help.
thanks
Re: FITTING MTEC 2 BODYKIT
Posted: Fri Feb 09, 2007 10:46 pm
by E30Mark
http://www.e30zone.net/modules.php?name ... chmtec.htm
I've got a load of the clips that fit along the top edge of the lower valence if you need any :D
Posted: Fri Feb 09, 2007 10:52 pm
by jazzleeds
are you selling them and how do i purchase them from u
thanks
Posted: Sat Feb 10, 2007 9:57 am
by E30Mark
jazzleeds wrote:are you selling them and how do i purchase them from u
thanks
I had to buy a bag of 25 from the dealer as they won't split bags... anyway they were about 30p each, and you need 7 of them.
PM me your address and i'll get some sent to you if you still need them, How does £3 all in sound! Paypal is easiest... :D
Posted: Sat Feb 10, 2007 10:17 am
by johnt0709
Hi - I have just fitted a m tech 2 valance - save yourself a lot of grief - get 8 cut the lugs off one (the part that pushes into the holes you need to drill in the lower valance of your car)
You can then push this onto your m tech lower valance and use it as a template to drill the holes in the proper position. The m tech valance will sit on the car as it wraps around the front wings. hope this makes sense? It took me 5mins to mark and drill. You also need plugs for underneath, but these are normally a stock item and you can buy them individually. winkeye
