7.5x16 ET30 wheels
Posted: Wed Aug 02, 2006 10:20 pm
Is it possible to fit 7.5x16 ET30 on 318i (drums on rear axle) without any spacers? And if I will fit 225/45R16 on it, will I have any problems with arches?
Cheers,
Jan
Cheers,
Jan
Firstly, for that size rim with that offset of ET30, you would need 5mm spacers for it to sit as it should at ET25. If not they will sit too far to the caliper and reduce handling efficency. This is based on correct tyre size of 205/50/16 tyres.Yaninnya wrote:Is it possible to fit 7.5x16 ET30 on 318i (drums on rear axle) without any spacers? And if I will fit 225/45R16 on it, will I have any problems with arches?
Cheers,
Jan
For this set up, the correct offset for the rim is ET26.bigmattpowell wrote:while we're at it, how about 7 x 15 with 205 rubber et 35 (discs all round)? Cheers
16 x 7.5j with an offset of 30 is listed to fit depending on rubber size.massive wrote:Firstly, for that size rim with that offset of ET30, you would need 5mm spacers for it to sit as it should at ET25. If not they will sit too far to the caliper and reduce handling efficency. This is based on correct tyre size of 205/50/60 tyres.Yaninnya wrote:Is it possible to fit 7.5x16 ET30 on 318i (drums on rear axle) without any spacers? And if I will fit 225/45R16 on it, will I have any problems with arches?
Cheers,
Jan
By having the tyre size 225/45/16 will not only put you speedo out but you may also need an additional 5mm on the spacer.
This is the way i understand it
HTH
Rubber size 205/50/16JAMZ wrote:16 x 7.5j with an offset of 30 is listed to fit depending on rubber size.massive wrote:Firstly, for that size rim with that offset of ET30, you would need 5mm spacers for it to sit as it should at ET25. If not they will sit too far to the caliper and reduce handling efficency. This is based on correct tyre size of 205/50/60 tyres.Yaninnya wrote:Is it possible to fit 7.5x16 ET30 on 318i (drums on rear axle) without any spacers? And if I will fit 225/45R16 on it, will I have any problems with arches?
Cheers,
Jan
HTH
You can't notice that 5 mm difference during even fast road driving .massive wrote:Firstly, for that size rim with that offset of ET30, you would need 5mm spacers for it to sit as it should at ET25. If not they will sit too far to the caliper and reduce handling efficency.
Why? 205/50 and 225/45 have the same diameter.massive wrote:By having the tyre size 225/45/16 will not only put you speedo out .
Good news! I have standard suspension height (off road styleJAMZ wrote:16 x 7.5j with an offset of 30 is listed to fit depending on rubber size. The offset of 25 is recommended but not essential on the e30..there is room either way..could get rubbing on full lock for instance,might hit strut if youve got 3 peeps in the back going over bumps...
205/50 is too narrow for 7.5' rim. 7' is maximum for 205/50.massive wrote:Rubber size 205/50/16JAMZ wrote:16 x 7.5j with an offset of 30 is listed to fit depending on rubber size.
Dont understand what this meant however, I didnt say it wouldn't fit, just said for the CORRECT offset you'd need a 5mm spacer. Perhaps 5mm negative offset wont make a noticable difference.You can't notice that 5 mm difference during even fast road driving
Errr how did you come to that conclusionWhy? 205/50 and 225/45 have the same diameter.
Strange that, Ive got 205 tyres on my 7.5J x 17205/50 is too narrow for 7.5' rim. 7' is maximum for 205/50.
It means that if the offset is much different it will afect the car handling. 5 mm is marginal.massive wrote:Dont understand what this meant however, I didnt say it wouldn't fit, just said for the CORRECT offset you'd need a 5mm spacer. Perhaps 5mm negative offset wont make a noticable difference.You can't notice that 5 mm difference during even fast road driving
massive wrote:Errr how did you come to that conclusionWhy? 205/50 and 225/45 have the same diameter.![]()
205/50/16.....the middle part is the profile so there is 5mm difference between the two. By having 45 as the profile will make the overall wheel and tyre diameter smaller.....and put your speedo out
And the rim is wider than tyre, isn't it?massive wrote:Strange that, Ive got 205 tyres on my 7.5J x 17205/50 is too narrow for 7.5' rim. 7' is maximum for 205/50.
Your correct its a %, not mm as the guy above explained. Thats not important....the debate is whether a 205/50 tyre on a rim has a overall larger diameter than a 225/45.Yaninnya wrote:It means that if the offset is much different it will afect the car handling. 5 mm is marginal.massive wrote:Dont understand what this meant however, I didnt say it wouldn't fit, just said for the CORRECT offset you'd need a 5mm spacer. Perhaps 5mm negative offset wont make a noticable difference.You can't notice that 5 mm difference during even fast road drivingmassive wrote:Errr how did you come to that conclusionWhy? 205/50 and 225/45 have the same diameter.![]()
Absolutely not. Profile on road tyres (in slicks is usualy the overall diameter in size) is in % not mm.And the rim is wider than tyre, isn't it?massive wrote:Strange that, Ive got 205 tyres on my 7.5J x 17205/50 is too narrow for 7.5' rim. 7' is maximum for 205/50.
Bottle tops would have a different offset they are narrow as fookKos wrote:i've got 215, stretched on to an 8.5j,
on my 16" x 7.5j rims i rub 205/45 and 225/40, but you can also use 205/50 and 225/45
et30 should not be a problem, bottle caps are et33 or there abouts i belive, and most afetrmarke 17" rims are around et30
so your handling will not suffer any major draw backs
That wouldnt cause wobble.. thats yer wheel not on yer Hub correctly or there crap rims... pina reps BK's spring to mind..318-is wrote:my racing dynamic wheels were ET30 and above 80mph they wobbled like hell.
my hartges are et25 and there are no issues whatsoever
im sorry but im with massive on this one, why would BMW recommend a specific offset? its there for a reason so why abuse it? i reckon the 5mm would make a difference
Sorry, but it is. The tyre widh is overall so the tread is narrower. Also the widh of rim (in this case 7.5') is measured where tyre is sitting on rim. But you have side edges which are outside of the tyre. On the rims which I want to fit I have 215/40 in the past (Yokohamas - quite wide tyres) and the tyres where exactly as wide as rims. Michelins Pilot SX 205/50 where to narrow.orangecurry wrote:I've got 205/50/16 on my 7.5Jx16 Hartges
rim is NOT wider than the tyre
using a 'ruler' it looks to me like 8 inches is about 205mm, so 7.5J rim would be narrower than a 205 profile tyre
please correct my maths....
Must be only in America then cus a number of people have posted saying they run 205 on 7.5J rims....including myself.Yaninnya wrote:Sorry, but it is. The tyre widh is overall so the tread is narrower. Also the widh of rim (in this case 7.5') is measured where tyre is sitting on rim. But you have side edges which are outside of the tyre. On the rims which I want to fit I have 215/40 in the past (Yokohamas - quite wide tyres) and the tyres where exactly as wide as rims. Michelins Pilot SX 205/50 where to narrow.orangecurry wrote:I've got 205/50/16 on my 7.5Jx16 Hartges
CI means Channel Islands which you shoud know if you are from England. Second - have you any photos of your pictures? show me that...massive wrote:Must be only in America then cus a number of people have posted saying they run 205 on 7.5J rims....including myself.
Thats the information what I need. Thanks!micktdel wrote:I am running 7.5J 16" ET35 with 205/50/16 on. To get these on the front you need at least a 5mm spacer to clear the strut. On the back you don't have to worry unless your worried about the slight offset difference. This is something you won't notice driving unless your doing some track / hard driving.
well perhaps what we all should be saying is 'the wheels and tyres I have in front of me...'Yaninnya wrote:Sorry, but it is. The tyre widh is overall so the tread is narrower. Also the widh of rim (in this case 7.5') is measured where tyre is sitting on rim. But you have side edges which are outside of the tyre. On the rims which I want to fit I have 215/40 in the past (Yokohamas - quite wide tyres) and the tyres where exactly as wide as rims. Michelins Pilot SX 205/50 where to narrow.orangecurry wrote:I've got 205/50/16 on my 7.5Jx16 Hartges
Well saidorangecurry wrote:well perhaps what we all should be saying is 'the wheels and tyres I have in front of me...'Yaninnya wrote:Sorry, but it is. The tyre widh is overall so the tread is narrower. Also the widh of rim (in this case 7.5') is measured where tyre is sitting on rim. But you have side edges which are outside of the tyre. On the rims which I want to fit I have 215/40 in the past (Yokohamas - quite wide tyres) and the tyres where exactly as wide as rims. Michelins Pilot SX 205/50 where to narrow.orangecurry wrote:I've got 205/50/16 on my 7.5Jx16 Hartges
I swop my 7.5Jx16s 205s every year (I run them as winter wheels), and when I lie them flat on the ground the rims don't touch the ground because the tyre is wider than the rim.
What you get on the 'zone is peoples actual experience, rather than armchair nonsense ; so there are 3 'zoners who actually have 205 tyres - that's all we are trying to say. Not telling you what to buy.
As to 'affecting the handling', as our wheels have the correct offset, if there is a handling issue, you'll be the one who has that, with wider tyres set too far in.
What's the ET's?tregzybmw wrote:to add to the tyre fitting discussions...
my mate has hartage alloys, fronts are 8.5j and are running 205's, rear alloys are 9.5j and are running 225's
topic here:
Cruise-south-west
That is silly stretched.....bet you dont let your misses drive that suckatregzybmw wrote:to add to the tyre fitting discussions...
topic here:
Cruise-south-west
You still do not understand me. The rim is not touching the ground. But what about the tread? Is it touching the ground as well? I dont think so. Also for 90% your tyres have RPB (Rim Protection Bar).orangecurry wrote: well perhaps what we all should be saying is 'the wheels and tyres I have in front of me...'
