MINI schnitzer 17's????
Posted: Sun Dec 11, 2005 1:25 pm
by Conan
Posted: Sun Dec 11, 2005 3:26 pm
by JoeP
I'm pretty sure I saw an E30 over here, I'm currently working in Bavaria, with those on the other day. If not them then very similar.
Posted: Sun Dec 11, 2005 3:34 pm
by parksie
Sure they'll fit but with spacers.
Posted: Sun Dec 11, 2005 4:03 pm
by Conan
Will spacers effect the ride, handling at all?
Posted: Sun Dec 11, 2005 5:47 pm
by parksie
I genuinely don't know, but i've got 15mm spacers on my other BM with no probs at all,so go for it and tell us what there like .
Posted: Sun Dec 11, 2005 5:56 pm
by Jordan
The hub bore is too small! I don't recall the exact size, but you would have to machine out the hub bore on all 4 wheels to 57.1mm to fit them on a e30.
Then you would also need spacers as they are going to be a high offset.
Posted: Tue Jan 03, 2006 7:01 am
by Geoffsco
ACS used to make 16' rims for e30's. Are you sure they were 17's?
Posted: Wed Jan 04, 2006 2:39 am
by Kos
replica ones are available, but only seen them available in the far east in malaysia.
get som blanks for an e36 and get them drilled to your bolt patern an machine the offset
Posted: Wed Jan 04, 2006 8:23 am
by A1BMW325iSport
Jordan wrote:The hub bore is too small! I don't recall the exact size, but you would have to machine out the hub bore on all 4 wheels to 57.1mm to fit them on a e30.
thats my opinion also, i looked into it a while back and didn't have much luck but i would really like some AC's
Posted: Thu Jan 05, 2006 5:34 pm
by parksie
You guys were right !!!
The Mini hub size is 56.1mm, maybe get a good half round file ?????
Posted: Thu Jan 05, 2006 8:02 pm
by A1BMW325iSport
anyone know what exact size spacers would be needed?
Posted: Thu Jan 05, 2006 11:31 pm
by Johan99
If you using good spacers with nuts you can have E30 hub size on the inside and Minis hub size on the outside.
Hope you understand what I mean
Posted: Fri Jan 06, 2006 6:57 pm
by parksie
You're dead right !!theres a guy on ebay offering to make spacers to any spec Ԛ£120 all in.
