Soundeadening done right
Posted: Sun Jun 30, 2013 3:17 pm
I've been looking into sounddeadening for the past while and have compiled a list of whet way I'm going to do it and using what products. Anyone here experienced enough to have a look and comment on the below (from talkaudio where im getting o feedback)
[/quote]I'm getting my shell back from the painter over the next couple of weeks and one of the first things I want to do is get deadening the thing.
Car I have is a E30 3 series touring with absolutely no sound deadening/proofing what so ever! I stripped out the old original stuff before painting the interior and now want to replace it and make things a little quieter while I'm at it. One concern I have is will it all fit under my carpet and also I don't want to add to much weight doing thi so with that in mind how does this shopping list look for making it better than standard?
Silent Coat 2mm Damping Mat- 25-50% coverage - 1x bulk pack will give me approx 50% coverage going by rough measurements
Foam Solutions CCF 3mm - cover the whole floor, wheel arches and behind the dash
Tecsound 35, 1.7mm- same coverage as CCF
Thats 7mm thickness which I've no idea of being able to fit under the carpet and behind the dash etc. I thought of going with Techsound sy50s but its just that little bit heavier. Overall I should have an improvement over standard and enough materials to double up where I can if I have to.
I'm going to be leaving the 4x doors for another time unless I have enough materials left over to put some techsound behind the door panels.
