amp wire routing
Posted: Fri Jun 25, 2010 1:01 pm
by kniterider
when i get the car back il be adding some speakers to it that i wanna run from amps. just wondered where the best spot was to route the wires fromas my battery is in the engine bay and dont really wanna faff around fitting it in the boot.
cheers all.
Re: amp wire routing
Posted: Fri Jun 25, 2010 1:41 pm
by ImysE30
The way i've done it is to run the amp wires down the driver's side of the car, behind the kick panels and then through the rear panel where the seats attach to.
Posted: Fri Jun 25, 2010 2:35 pm
by kniterider
The best way to het from the enginebay to the cabin tho? Are there any holes?
Posted: Fri Jun 25, 2010 2:51 pm
by ImysE30
Where the ECU plug goes through, i drilled an extra hole in the gromet, think there might be a spare one though?
Got a pic somewhere, will see if i can find it.
Posted: Fri Jun 25, 2010 3:07 pm
by ImysE30
Posted: Fri Jun 25, 2010 3:16 pm
by kniterider
Your a scholor and a gentleman. Does anything inside need to be remove to retrieve the end? And is it easy enough to run the wires from the back of the headunit out the dash somewhere?
Posted: Fri Jun 25, 2010 3:41 pm
by ImysE30
You just need to remove the under dash panel (above the pedals) and you'll be able to retrieve it.
I routed the headunit amp wires underneath the steering column and along the drivers side panel.
