polished lip
Posted: Mon Apr 26, 2010 2:33 pm
by Jonny_92
has anybody tried polishing the lips on bbs 14 or 15" alloys themselves?
Re: polished lip
Posted: Tue Apr 27, 2010 12:01 am
by FMH
easy, get various grades of sanding sheets, starting with 80 grit and work your way up
Re: polished lip
Posted: Tue Apr 27, 2010 12:33 am
by leeparkes
Its easy to do but to keep them shiny is a different story :banghead:
As said work your way up with grades of wet and dry then finish off with a polish, avoid autosol, duraglit etc as you need something to protect from them from everyday filth on the roads and brakedust
Ive gone through loads of polish but ive found this the best, has anti corrosive, easy to use and brings them up like a mirror 8)
Re: polished lip
Posted: Tue Apr 27, 2010 12:35 am
by JWaller360
What about polishing, then lacquering? Thats what I'm planning when I refurb my BBS
Re: polished lip
Posted: Tue Apr 27, 2010 12:36 am
by FMH
JWaller360 wrote:What about polishing, then lacquering? Thats what I'm planning when I refurb my BBS
You will loose a bit of shine but they will still stand out.
Re: polished lip
Posted: Tue Apr 27, 2010 12:41 am
by gra325i
the laquer will just peel and crack within six months..thats what happened to mine..
the nature of laquer is that when spraying it onto paint it should be "wet coated" over the top coat while it is still tacky so that the laquer may adhere with the paint..it just does'nt last on bare metal :(
Re: polished lip
by leeparkes
And they go 'milky' if you chip it when water gets under the lacquer
Edit: must type faster :D
Re: polished lip
Posted: Tue Apr 27, 2010 12:43 am
by JWaller360
ahh I see.
Bugger.
Re: polished lip
Posted: Thu Apr 29, 2010 9:12 am
by kam325itouring
i got mine done from a metal polishers.
