Vinal Hardtop, can it be sprayed
chisel
Hi peeps
I’ve seen a hardtop on the Bay in vinyl blue, being vinyl is it possible to strip it back to metal and paint it?????
Charlie
Charlie
I'm pretty sure you can, the guy selling that hardtop is a zoner on here
Zizzle
Not metal charlie... its fiberglass underneath.. you have to strip the vinyl... then take off all the glue.. prep it then paint it!
DaveD
- E30Zone Wiki Specialist
a real pain of a job ...dont expect to do it in 5 minutes ...my sprayer said don't bring me another...
Zizzle
YEP!!! proper b*ll ache.. also recomended in an oven other wise sometimes the fiberglass warps and paint bubbles up... it can look awful......
GOOD LUCK!
GOOD LUCK!
reaz12345
i did all above. the finish product was wicked however 2months down the line bubbles appered everywhere.
it look nasy so i sold it.
i dnt know if it can be painted and not bubble up
find yr self A goog painter mine was shit.
if done right it will look wicked
How much would you reckon it would cost to get it done properly?
dips346
- London Meets Main Man
its how you do the prep work,you can NOT use any machines or solvents as all this makes the fibreglass heat up and warp and solvents soak in and then trys to escape once paint hence the bubbling ,the labour is high to do them as it alot of old fashion man power ,zizzle oven has nothing to do with it
What would people charge to do this sort of work?
DaveD
£400 +
chisel
cheers fellas, sounds like i'd be better off holding out for something else. Cheers for the responses.
dips346
about £500ImysE30 wrote:What would people charge to do this sort of work?
Zizzle
Yeah what dips said...
ive jus seeen them in ovens coooking thats all... !!!
Probably cost in the region of about £1200-£1300 to get one done then unless someone has a lagoon green one already done
