how to remove front speakers in cabby
ianjon
Sun Feb 10, 2008 7:05 pm
hope you can help what is the simplest way to remove the speakers at front of cabby and replace with speakers any speaker suggestions would
be helpful too with good quality sound thank for your time 8)
whipsey
Sun Feb 10, 2008 7:30 pm
easy job remove the sill trims then the one screw that holds the speaker grille in place replace with some decent components which ones depend on what sort of music you want from them bassy etc
secondtimelucky
Sun Feb 10, 2008 7:32 pm
Isnt it the same as all other e30s?? ie, remove kick panels (two screws each IIRC) then four screws per speaker holding them in, replace with chosen speakers of 5.25" size and then put everything back together and enjoy :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
cliffybabe
Powered by Nelly
Powered by Nelly
Sun Feb 10, 2008 7:33 pm
secondtimelucky wrote:Isnt it the same as all other e30s?? ie, remove kick panels (two screws each IIRC) then four screws per speaker holding them in, replace with chosen speakers of 5.25" size and then put everything back together and enjoy :D
yep 8)
whipsey
cabs have plastic trims inside due to the bigger sills otherwise its the same
ianjon
Sun Feb 10, 2008 8:07 pm
:) cheers for your help will tackle this at weekend!!!
padi
Fri Feb 15, 2008 2:53 pm
Just to add like whipsey says, take the sill covers off, it takes a little more time but saves from braking bits. I also found the dropping the cover from under the steering column helped lots on the drivers side... :D
ianjon
Tue Feb 19, 2008 1:22 pm
:D cheers for the advice new speakers all round !!!
