supercharging a 318i
Posted: Tue May 31, 2005 9:13 am
by AndyBird
i am intending to do this as a practise before i twin charge my 200sx.
using a mini superchager i reckon about 160-180 bhp Ԛ£100.
intercooler got a fmic in my gargage
Ԛ£0
Will the zone chips cope with a supercharger should do as its only a matter of fuelling and timing alterations Ԛ£?
Pipework and inlet manifold i can do my self as i can weld and get hold of tube v cheap
Ԛ£50
will the 318 M40 engine handle the supercharger or will i need a thicker head gasket to drop the compression ratio?
Posted: Tue May 31, 2005 1:43 pm
by Turbo-Brown
Might be useful to take a look at the supercharging an M40 topic on this one
Doesn't sound like you're after huge power so with any luck the standard CR should be fine.
Not sure about the Zone Chip, my first thought would be that it wouldn't be suitable, but someone will be able to tell you for sure
Posted: Tue May 31, 2005 4:00 pm
by AndyBird
the only bits im not sure on is the clutch, injectors and fuel pump limitations.
are they listed somewhere? sorry search police
Posted: Tue May 31, 2005 5:02 pm
by Turbo-Brown
Pump should be fine I think, I've had to upgrade my injectors though.
I'm gonna be using the standard clutch for the 325i, not sure if it'll be enough or if the standard 318 one'll cope either.
Posted: Tue May 31, 2005 6:47 pm
by Matt
i'm thinking of doing this to my m10 but thought the mini supercharger wouldn't be powerfull enough as they are a 1.6.
Posted: Tue May 31, 2005 6:50 pm
by Sjoerd320i
I think the chip can handle it because ant makes them himself so I guess he can make some alterations(spel) to one??!
Posted: Tue May 31, 2005 6:52 pm
by Jhonno
Matt wrote:i'm thinking of doing this to my m10 but thought the mini supercharger wouldn't be powerfull enough as they are a 1.6.
its more power output than engine capacity
Posted: Tue May 31, 2005 7:07 pm
by Matt
surely though if its ok for the mini at 1.6 lts then at top end on mine the power output wouldn't be big enough
by Jos
Have a look at the M42 thread, it shows a lot of the technical info regarding the Eaton M45 Supercharger (thanks to Turbo-Brown) It will run a 1.8 no problem.
Posted: Tue May 31, 2005 7:15 pm
by Jhonno
Matt wrote:surely though if its ok for the mini at 1.6 lts then at top end on mine the power output wouldn't be big enough
power requires a certain amount of fuel/air to get.. the charger will work fine with a 1.8.. its the power thats more important not the engine size
Posted: Tue May 31, 2005 7:24 pm
by Jos
with a 1.8, assuming 85% VE you could run about 7psi of boost, this at 7000 rpm is about 280CFM, the M45 can do about 320CFM or so at top whack. This would give about a 40% gain in horsepower (using Turbo-Browns simple idea of % increase in air)
Posted: Tue May 31, 2005 7:29 pm
by Jos
Quick look at the numbers for the M40
115hp stock, 40% increase is about 150hp or so..
Just get an M42 engine, it would be cheaper and easier.
Posted: Tue May 31, 2005 7:33 pm
by 320Touring
Jos wrote:Quick look at the numbers for the M40
but not as much fun! WHIIIIIRRRRRRRRRRRRRR
Posted: Tue May 31, 2005 9:14 pm
by AndyBird
whats a M42 engine?
Posted: Tue May 31, 2005 9:17 pm
by 320Touring
AndyBird wrote:whats a M42 engine?
its a 1.8 4cyl 16valve (twin cam) bmw engine as found in the e30 318iS
Fairly rapid for "4pot wrongness" and a good engine to drive...
should be a couple available in the 'for sale' section...
Posted: Tue May 31, 2005 9:18 pm
by Borderbmw
Are you still out there Neil?
Posted: Tue May 31, 2005 9:20 pm
by 320Touring
Borderbmw wrote:Are you still out there Neil?
yeah!!!? why dude?!
Posted: Tue May 31, 2005 9:23 pm
by Borderbmw
Just thought id tell ya i got the job at Travis perkins,i got a phone call at 5pm tonight
,thank god......any longer and ive shoved me head in the oven!
(except its electric!)
Posted: Tue May 31, 2005 9:28 pm
by 320Touring
Posted: Tue May 31, 2005 9:31 pm
by Borderbmw
Doubt ours would its shite!!
,im still due to go to college for an inetrview on thursday too.......Jesus! nothing happens and then it all comes at once
Posted: Tue May 31, 2005 9:32 pm
by 320Touring
Borderbmw wrote:Doubt ours would its sh*t!!
its what makes life interesting
what college course are you gonna do?!
if you're smart you can probably do something associated with Travis Perkins trade, and do it day release so you get educated and paid at the same time?!!!
Posted: Tue May 31, 2005 9:38 pm
by Borderbmw
I applied to study agricultural engineering as i couldnt get a job despite applying for everything i could,and i got the interview for college on thursday.
I wanted to go back to college as im already a qualified mechanic and welder,so i thought id extend my training! fu***** typical!
We must stop hijacking peoples threads for our conversations!
Sorry
Posted: Tue May 31, 2005 9:41 pm
by 320Touring
lol! maybe use the PM's then??
wasnt Auchincruive perchance?!..
sure you could link the gravel and building stuff into agriculture?!
Posted: Tue May 31, 2005 9:45 pm
by Borderbmw
Nah it was Barony college near Dumfries,but if i get on ok at TP i might be able to do a construction management course or something....or surveying maybe,i quite enjoy construction stuff too
Posted: Tue May 31, 2005 9:51 pm
by Borderbmw
Neil,just pm'd you to see if its working?
Re: supercharging a 318i
Posted: Tue May 31, 2005 10:40 pm
by Turbo-Brown
AndyBird wrote:i am intending to do this as a practise before i twin charge my 200sx.
Just out of interest, how much power you aiming for from the 200sx and is it to be twin turbo or super?
Posted: Wed Jun 01, 2005 10:21 am
by AndyBird
Turbo-Brown wrote:AndyBird wrote:i am intending to do this as a practise before i twin charge my 200sx.
200sx will be turbo and supercharged will be tuned to run approx 450bhp on a m90 or 112 eaton blower and T38 turbo on about 1.6 bar.
back to the 1.8............ the power increase of 40% is without intercooling or anything else the 40% increase is bolting onto a standard engine for example silvia S12 RSX has the CA18DET engine turbod but not intercooleed and runs about 140bhp the S13 200sx runs the CA18DET intercooled and runs 170bhp.
Posted: Wed Jun 01, 2005 1:34 pm
by Turbo-Brown
Ooh, compound charging
Gonna be fun setting that up! Think someone posted a vid of an E36 M3 on the rollers which was compound charged. Sounded fooking wicked!
Posted: Wed Jun 01, 2005 3:21 pm
by AndyBird
i reckon 160-180bhp could be seen with the M40 with the mini supercharger i an use the intercooler ive got, exhaust and filter, and some management from Ant.
The management wouldnt be that hard its only fuelling and timing at the end of the day.... pulling the timing back a bit up the top end and increasing the injector duty cycle
Posted: Thu Jun 02, 2005 12:05 pm
by Donnie
Turbo-Brown wrote:Ooh, compound charging
Was it a white one, probably the one Savspeed here in South Africa is building, I saw, and heard it in real life, Sav showed he got 320km/h on a stretch with his gps or something
Posted: Thu Jun 02, 2005 2:00 pm
by Turbo-Brown
Think it was white yeah, looked like it was trying to climb out of the rollers
