Exhaust piping
Posted: Mon Aug 06, 2007 9:23 pm
by Jhonno
Im after some piping to join up a system.. link has been posted on here befoe but a quick search hasnt brought it up..
2" inc a 90deg bend..
Re: Exhaust piping
Posted: Mon Aug 06, 2007 11:22 pm
by Turbo-Brown
try milneroffroad.com if you want stainless stuff :D
Re: Exhaust piping
Posted: Mon Aug 06, 2007 11:27 pm
by Jhonno
quick if slightly retarded Q.. when you buy piping, it all same dia.. so how do you join 'sections' together?
Re: Exhaust piping
Posted: Tue Aug 07, 2007 8:40 am
by JazzMan
I used http://www.jetex.co.uk/website/custom_parts.php pipes, didn't know where else to get them at the time, quality seems fine though. Although only time will tell. They have an expanded bit at one end that the next pipe can slot into. You can then use a clamp or weld them. The Jetex clamps are not brilliant I'd look for something better there.
Re: Exhaust piping
Posted: Tue Aug 07, 2007 9:11 am
by racecar
pretty sure joe @ btb sells components/tubing/bends etc:
01327 261797
Re: Exhaust piping
Posted: Tue Aug 07, 2007 1:44 pm
by Turbo-Brown
If the sections are all the same size then you can either buy sleeves which clamp over the outside of both bits, or run a seam weld around :D
Re: Exhaust piping
Posted: Tue Aug 07, 2007 3:21 pm
by ric325i
jetex bits tend to be very long which it very useful!
its easier to chop down that add more.
i like the sleeve idea turbo-brown :D
but me and Gall are using flanges which is an option but it depends on where the bits are you joining Jhonno.
just a suggestion. makes that section detachable too :D
Re: Exhaust piping
Posted: Tue Aug 07, 2007 3:52 pm
by ric325i
oops i just put loads of pics in here.
wrong thread. :roll:
Re: Exhaust piping
Posted: Tue Aug 07, 2007 8:55 pm
by Jhonno
bought a load 4 bout £65.. need a tiny bit moe straight section i believe, but will know moe once my silencer arrives.. then i can position, tack, then weld me thinks
Re: Exhaust piping
Posted: Tue Aug 07, 2007 10:10 pm
by jmc330i
Are you having just a rear box or centre box as well?
Im going to get some of the Jetex stuff to fill the gap between the X-pipe and rear section that I have. I need to have a proper look (it was my day off today, so it was chucking it down) but I think all I need is a couple 90deg bends, a couple flanges so I can split it and a couple straight sections.
My brother has got me a centre box but Ive not seen it yet. Im not sure on the size so it may be too big to fit without causing ground clearance problems.
Re: Exhaust piping
Posted: Tue Aug 07, 2007 10:45 pm
by Jhonno
ooo flange is a good idea.. hmmm
yeah you need 2 90, 2 45 and 2 30 from what ive done.. plus the straight bits, i think 2 1/2m bits and then another short straight section to the backbox
im not using a middle box now.. just a supersprint backbox
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:07 pm
by jmc330i
My rearbox should almost fit like a 2 piece M20 system, so Im hoping I only need 2 90deg bends from the end of the X-pipe to run straight back.
It should be fairly noticeable with just a rearbox fitted - Im still thinking about the side exit pipes :twisted: :D
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:11 pm
by Jhonno
well mine is a race supersprint backbox..
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:18 pm
by jmc330i
If thats anything like the exhaust Simon had on his M3 (Im sure that was supersprint), that will be very noticeable :eek: :D :twisted: :cool:
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:38 pm
by Jhonno
yup it is.. any sound clips you know of? Seem to remember one about..
my mileage is gonna be all pleasure this year so not so fussed by noise now.. tho if it gets too much attention may adjust..
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:39 pm
by Jhonno
hmmmmm :twisted:
Re: Exhaust piping
Posted: Tue Aug 07, 2007 11:45 pm
by Jhonno
unrelated but OMG!!
Re: Exhaust piping
Posted: Wed Aug 08, 2007 11:06 am
by Demlotcrew
Eisenmann make the best exhausts around!
Is that suppersprint race going to be very loud then? :eek:
I dont care should sound cool
