what setupn 4 2.7 turbo m20?
Posted: Tue Jul 31, 2007 2:00 pm
by hijak001
hey plp me again
i hav a question...would a 2.5 m20 head
on a 2.7 short block giv a low comp..
low enough 4 a turbo..
ur help wid dis is greatly appreciated
k catch ya's
Re: what setupn 4 2.7 turbo m20?
Posted: Tue Jul 31, 2007 2:18 pm
by 1an
there was a guy on here who did a 2.7 turbo, i believe Ant suggested that it was a bad idea doing a 2.7 turbo not to sure your probally best giving Ant a ring and speaking to him about these kind of things.
Posted: Tue Jul 31, 2007 2:20 pm
by maxfield
blingsta had a 2.7 turbo but had problems because he was running pretty hih compression.
With a low compression engine then 2.7 would be a sweet thing to turbo.
Posted: Tue Jul 31, 2007 7:18 pm
by Ant
I have 3 2.7 turbo projects in the workshop, the CR is the key to this conversion.
only ill advised on ETA cranks due to the weak cast iron nature and long stroke, TD or M52 cranks are stronger than the B25 unit so not an issue, all the converted engines I have built are riunning the TD crank
happy to field a few phone calls on this if you want BTW.
Blingsta was 10.4:1 CR + turbo , hance the Headgasket going into orbit once the boost climed above 8 psi.
Posted: Wed Aug 01, 2007 1:24 am
by blingsta
Posted: Fri Aug 03, 2007 12:44 am
by turbotel
or a decompression plate /copper gasket a safety valve in other words. this willbe the first item to go should something go wrong depending on what goes wrong. can get you number.
Posted: Fri Aug 03, 2007 12:51 am
by blingsta
Ferriday engineering can provide a decomp plate for £300.. 3mm is what i had but bought it too late...
Posted: Sun Aug 05, 2007 8:51 am
by hijak001
ic so the td crank ...
no da only prob i got is gettin 1 into australia..
oh well will a find way..
fanx 4 da help
Posted: Sun Aug 05, 2007 10:49 am
by cplagz
eta block, rods, crank + 325i pistons, head = low comp IIRC ? ~8-8.5 or something
Posted: Sun Aug 05, 2007 2:07 pm
by daimlerman
Is a 2.8 crank available in upsidedown land?Be stronger than the eta item,would eta pistons/2.8 crank give a useful starting point?
Posted: Sun Aug 05, 2007 2:47 pm
by fuzzy
hijak001 wrote:hey plp me again
k catch ya's
how come the text talk filter didnt sort this out?
Posted: Sun Aug 05, 2007 3:17 pm
by Colonel Sanders
maybe hes "special"
Posted: Sun Aug 05, 2007 3:38 pm
by hijak001
hurray i'm special...
lmao..
nah i got no idea y it hasn't
