M30 N/A Build, stock rod strength
Posted: Tue Sep 26, 2006 4:01 pm
I am building a N/A m30 to put in my e30 and have a question about the strength of the stock m30 rods.
First here is the jist of what is going to be done to the engine:
custom 10.5:1 pistons
.5 overbore, hone, resurface
head port/polish, resurface
3 angle valve job
probably a 284 cam
dual valve springs
balance/blueprint
Basically the question is will the stock rods be ok for this set up. I don't plan on having the engine rev much higher then 6500 rpm but this will be put into a road racing/drift car so it will experience the higher revs.
Custom rods are expensive and I have gotten a good deal on all the other work to fit it in my budget. I would like to use the stock rods from the donor engine, I have cleaned them and they look to be in great condition.
But can these rods handle this setup? Any advice is appreciated.
3 angle valve job
probably a 284 cam
dual valve springs
balance/blueprint
