tuning a Jetronic 320i
Posted: Thu Aug 31, 2006 3:10 pm
by dazzaboy
I posted a message the other day about tuning a 320i, unknown to me it is a jetronic type, i had a few tips on how to tune a motronic type like fitting a 325i throttle body and inlet manifold, will this still work with a jetronic, any tips would be great,
ps. I dont fancy fitting a whole 2.5 as the insurance wont like it too much
Re: tuning a Jetronic 320i
Posted: Thu Aug 31, 2006 4:42 pm
by Ant
Megasquirt ECU, its the only way to tweak these, there are no chips for the analogue setup you have, and with a dizzy and mech advance you'll have no joy there either dude.
try a tad more fuel pressure and a few degrees base advance more, will carry the extra right to the limiter, so be careful
HTH
Posted: Fri Sep 01, 2006 9:01 am
by 320Touring
A bigger bore throttle body, machined head to accept a 325i intake manifold
Posted: Fri Sep 01, 2006 9:07 am
by dazzaboy
I thought the 325i intake wouldnt work, only with a motronic setup, please correct me if i am wrong
Posted: Fri Sep 01, 2006 9:17 am
by 320Touring
dazzaboy wrote:I thought the 325i intake wouldnt work, only with a motronic setup, please correct me if i am wrong
as far as I was aware, it should work with either...
I await telling off though
Posted: Fri Sep 01, 2006 5:13 pm
by kirils
i have a 1983 320i with l-jetronic now is running in really slow, i could hardly manage to drive 180km/h
... that is after i was messing with the timing belt and dizzy cap. first i set it up and it was really fast, it was like driving another car, but it wouldn't idle really hard starting etc.. so it's still not set up right i will need to take it to a sepcialist. so that is sure not helping...
where can these megasquir ecu be found?aand how much do they cost? my location is a bit odd Macedonia, and i'm 100% sure that i can find it here..
Posted: Fri Sep 01, 2006 8:20 pm
by ed325i
[quote]A bigger bore throttle body, machined head to accept a 325i intake manifold
Would this work on a 323?
Posted: Fri Sep 01, 2006 8:27 pm
by Speedtouch
A cheap & cheerful way to increase the rev limit on these (thus giving a bit more at the top end and not such a brutal cutoff in the power) is to remove the spring-loaded 'switch' on the rotor arm in the distributor. I did this with my first '84 320i and it blew away a Merc 500SL in a traffic lights grand prix
Recommend you have a cambelt in good condition before you try the mod though
Posted: Sat Sep 02, 2006 5:57 pm
by ed325i
Thanks argos I have got a 2.5 inlet and TB in the shed. What pressure can the fuel be raised to ?
Posted: Sat Sep 02, 2006 6:43 pm
by Ant
dont use motronic injectors with Jetronic or vs versa btw, the end result will be a fried ECU
Posted: Wed Sep 20, 2006 4:03 pm
by dazzaboy
Is there any thing else that can be done???
Also what sort of money am i looking at for a inlet manifold and or throttle body (pref big bore)
Posted: Wed Sep 20, 2006 6:45 pm
by ed325i
I would think a 325 inlet can be got for Ԛ£15/Ԛ£20.
I have got one in the shed waiting to go on.
Posted: Fri Sep 29, 2006 9:10 pm
by ed325i
All the pipes are the other side on the jetronic engine so fitting the 325 inlet would not be that easy.
Posted: Mon Feb 26, 2007 11:20 pm
by Speedtouch
Anyone ever done this conversion then? Also, which way do you rotate the dizzy to get the timing more advanced?
Cheers!
Posted: Tue Feb 27, 2007 3:33 pm
by ed325i
If I was you I would fit motronic. easy to do on a 320.
Posted: Tue Feb 27, 2007 3:49 pm
by Speedtouch
Is it really worth the effort for another 4bhp?
Posted: Sun Mar 04, 2007 10:21 pm
by Speedtouch
I tried turning my car's dizzy a few degrees anti-clockwise today; it seems to have made it a little more responsive, though the car's idling a little high at around 1,500rpm (also tried adjusting the throttle stop, to no avail).
Am I correct in thinking I should turn the dizzy anti-clockwise until it just begins to 'pink' going up a hill in 4th gear, then turn it back the other way slightly to get the optimum setting?
Cheers!
Posted: Mon Mar 05, 2007 8:39 am
by Ant
old scholl method, works though, used to be a fave trick on the mk1 gti, 4 degrees base timing certainly pepped mine up
