635csi motor?
Posted: Tue Jan 24, 2006 7:07 pm
by Gravy
Hi guys
Can use a 1982 635csi motor for a 3.5l conversion into my touring? I read its easier to break an E34 535i but I don't know the reason why? Are these engines not the same?
I would appreciate your help because I have the chance of this 6 series and an E32 730i manual and therefore I could mate the two together if this is a route I could take?
Thanks for the help
Rob
Re: 635csi motor?
Posted: Tue Jan 24, 2006 7:16 pm
by Kos
Gravy wrote:Hi guys
Thanks for the help
Rob
the e34 sump is the one you need, with oil pick up in the right place.
the e32 sump should be ok
Posted: Tue Jan 24, 2006 7:22 pm
by Gravy
so i could do a conversion using htese two cars then? I could use the sump off the E32 and put it on the motor from the 635 or does it not work like this?
Basically I need to know whether I go for these cars or just wait untill a suitable E34 535i manual comes up for sale?
Posted: Tue Jan 24, 2006 11:31 pm
by Toby_Unna
1982 is on the changeover from jetronic (i think) to motronic with 635s. if it;s jetronic forget it, way too old and the inlet plenum is the wrong shape.
if the 635 is auto forget it too. assuming it's motronic, these older gen engines have motronic speed/reference sensors on the gearbox bellhousing. the e34/e32 engines don't as the sensor is at the front, but older 635s do, the e34/e32 manual box won't be any use with the older motronic engine as they don't have mounts for these sensors.
i'd leave it myself. other small reasons like the older engines have a water pipe on the rear of the head which causes clearance issues.
as you suggest, e34 535i manual the way forward...
Posted: Wed Jan 25, 2006 12:03 am
by Gravy
Cheers mate thats exactly the advice I was looking for!
I think I had realised that this evening anyway, seems to be a couple of cheap E34's knocking around so that's definately my plan of action now!
Thanks again
Posted: Wed Jan 25, 2006 9:38 pm
by gareth
if the E32 manual is cheap, it may well be worth getting that for the manual parts. i bought a 375i auto for Ԛ£100 for the engine but spent over twice that tracking down the various manual parts needed. a clutch is Ԛ£100-180, + prop for donor (Ԛ£50) + flywheel + gearbox etc etc etc. also, if you get the whole setup from the 730i, you can then pick up a bare 3.5 lump and an ecu without much hassle to get the complete setup.
my parts came from a huge load of various donors. (E28 M535i rad/bottom hose/clutch/flywheel, E30 M3 prop/exhaust, E32 735i engine/loom/ecu etc, E34 530i gearbox etc etc!!!)
a single donor will make life a lot easier if you can find one and like you say a single E34 535i manual will be the best donor, if you can find one that's been looked after but now broken, this i failed on!!!
Posted: Thu Jan 26, 2006 2:59 pm
by Gravy
Yeh Gareth, I must admit that this is causing me some dilema, I know this 730i is going to be kicking around for a while so I do have time on my side to have a good search for the E34 (and get my MGB GT sold which is taking up valuable garage space!).
I think I'll search and search but then if nothing fruitful turns up then I will bag the 7 for the reasons you highlighted.
Thanks for your help and insight!
Incidently, what sort of pace can I expect from this conversion - my mate has an E34 535i sport auto and it feels swift, but I imagine in an E30 it's a proper flying machine with all that torque combined with light-weight shell? It seems a no-brainer conversion in terms of acheiving a cheap sleeper car. In-gear acceleration must surely be impressive, if it feels as swift as a 330d in-gear sprints then I'll be well chuffed!
Posted: Thu Jan 26, 2006 5:36 pm
by Toby_Unna
mine (E34 engine in standard tune) would do 60mph in six seconds dead and indicate 150 fairly easily (that was on the rev limiter, so although it probably was going slower there was more to come)
pretty much identical through the gears to a friend's 1990 911 3.6, but i'll beat him once this turbo's on
Posted: Thu Jan 26, 2006 7:08 pm
by Gravy
Awesome mate! Your turbo conversion looks mint, I have been following your thread
Standard tune sounds quick enough for me, if I can acheive those figures you said, then we're talking sausages!!! Thats exactly the pace I was hoping for - 6 seconds dead is plenty respectable enough, lots of traffic light fun and definate chav car killer (especially if I leave the 318i badge on the boot), not that i'd condone that type of behaviour......
Posted: Thu Jan 26, 2006 7:29 pm
by Toby_Unna
Gravy wrote: lots of traffic light fun and definate chav car killer (especially if I leave the 318i badge on the boot), not that i'd condone that type of behaviour......
i would condone it
316i
Posted: Thu Jan 26, 2006 7:40 pm
by Gravy
Pure class, were they cecotto wheels? I just noticed your based in Leicestershire, where abouts if you don't mind me asking? I'm in Loughborough so maybe I could tap you up face to face for some information on doing the conversion when I am ready to do it?
Tell me where to go if that sounds cheeky!
Rob
Posted: Thu Jan 26, 2006 7:45 pm
by Toby_Unna
put LE7 9AL into multimap.com mate
1/2 hr from loughborough, you're welcome anytime for a chat, unfortunately can't take you out for a spin as it's in a lot of bits
Posted: Thu Jan 26, 2006 7:58 pm
by Gravy
You're a diamond! Not too far away at all, I'll be in touch in the next couple of weeks if all goes to plan, cheers for the offer!
Posted: Thu Jan 26, 2006 8:32 pm
by Andy335Touring
I'm not far from you, i'm in Long Eaton.
I need a 316 badge
Posted: Thu Jan 26, 2006 9:03 pm
by gareth
this talk is getting me all excited!!!! i can't wait to get mine of the road!
hopefully by next week i'll have the lump in and mostly set up...
Posted: Thu Jan 26, 2006 9:11 pm
by Batch
Toby_Unna wrote:1982 is on the changeover from jetronic (i think) to motronic with 635s. if it;s jetronic forget it, way too old and the inlet plenum is the wrong shape.
The old m30 engines (the ones that came in e23/e28) will suit only the manual gearbox from old engines - the ones that have sockets for those sensors. In my case the only problem was finding the right flywheel (as i have no donor car i had to collect all the bits), because the flywheel i have has no snag for one of these sensors. The sollution is to weld it to the flywheel and then get the flysheel ballanced. But anyway it's rather big ball ache..
Posted: Fri Jan 27, 2006 8:56 am
by Gravy
Andy335Touring wrote:I'm not far from you, i'm in Long Eaton.
I need a 316 badge
Yeh Andy335iTouring, I pm'd you not too long ago, we said we should arrange a meet because i'd like to see your car too for inspiration and advice! - its exactly how mines gona be (except mines laser blue).
Out of interest, does anyone know how many 3.5l tourings there are on the site or even in the country? It still must be a fairly rare contraption?!!
I suppose it's O/T but it would be cool to arange an East midlands meet, perahps I'll search the 'Meets' forum and see whats happening!
Cheers all
Posted: Fri Jan 27, 2006 9:54 am
by cpc
Agreed.
The chances of getting hold of a nice corrosion free early M30B34 are pretty slim now. Also ,don,t forget the E32/4 3.5 engines have larger intake ports and 47mm inlet valves as oppsoed to 46mm fitted to the earlier engines- this all helps. They are also smoother running, and there is a good chance you can find one that has had a recent cam / rocker repacement.
Posted: Fri Jan 27, 2006 2:11 pm
by Toby_Unna
http://cgi.ebay.co.uk/bmw-535i-being-so ... dZViewItem
this is what you want.
looks like a manual as there's a clutch res visible
67p no bids at the moment
much better than messing about with ancient 635s!
Posted: Fri Jan 27, 2006 3:56 pm
by Gravy
Thnanks for that info cpc, i'm definately going to ignore the 635 now!
I saw that 535i Toby and it looks like it could be a bit of a steal - maybe I'll ask some questions about it!
Thaks again for everyones input
Rob
Posted: Fri Jan 27, 2006 7:38 pm
by gareth
Gravy wrote: Out of interest, does anyone know how many 3.5l tourings there are on the site or even in the country? It still must be a fairly rare contraption?!!
well, i know of andys, one i saw on ebay a year or so ago (flat blue iirc) and within the next week, mine! the engine is going in tomorrow!
Posted: Fri Jan 27, 2006 9:16 pm
by Andy335Touring
Shame we don't all live closer for a 335 meet this summer when they are all finished !
There was a thread for a midlands meet Tamworth side of brum but it didn't get much response
Rob if you want to pop over some time just give me a shout mate
Posted: Sun Jan 29, 2006 10:54 am
by Gravy
Cheers mate I will take you up on that offer for sure! - I missed that 535i that Toby put a link to above to ebay because of storage issues, must sell one car before I get another!
