AFM and MAF???????????
Posted: Thu Dec 01, 2005 2:57 pm
by Conan
Could some explain the difference?
what are the differences?
why is one more restrictive than the other
are MAF a good idea on something smaller than a 2.7 etc
CHEERS
Posted: Thu Dec 01, 2005 3:19 pm
by M5pilot
AFM uses a flap system where it measure the volume of air.
MAf uses hot wire/hot mesh to calculate the MASS of air and works much fatser than an AFm and measures more accurately. Its also non restricitive and is basicaly near anough a hollow tube.
Gains seen before on a 2.5 are a minimum of 10bhp and 10 lb.ft torque peak and more throughout the rev range.
Well worth it especially combined with a 6 branch and BBTB.
Posted: Thu Dec 01, 2005 3:46 pm
by Conan
cheers, looking to buy a 2.7 of a mate and wondered the gains on that if i changed to MAF?
Posted: Thu Dec 01, 2005 5:02 pm
by Turbo-Brown
I'd look at the cost of the MAF compared to a mappable ECU setup as there might not be much in it, in which case you may well stand to gain more from the latter
Posted: Thu Dec 01, 2005 5:05 pm
by Jhonno
and give more choice later on should you choose to take it futher..
Posted: Fri Dec 02, 2005 3:46 am
by bedema
so.....what is the procedures and parts do it need to change my 325i into using air mass sensor unit?
thanks in advance?
