Volvo t5 engine
salty
Wed Sep 01, 2010 7:02 am
Hi guys. Has anyone ever fitted a Volvo t5 engine into an e30?
BornToBeE30
Wed Sep 01, 2010 12:21 pm
google it.
N00b
Wed Sep 01, 2010 7:16 pm
BornToBeE30 wrote:google it.
There's an old saying.
"For some moments in life, there are no words".
This was your moment.
Wed Sep 01, 2010 8:44 pm
Eko was making plans to do this swap ages ago, not heard anything more about it so I guess Tony thought better of it/ too much faffing aout
nickso
Wed Sep 01, 2010 10:17 pm
have a search on here, seems more hassle than it's worth. biggest problem being gearbox options and possibly sump.
'88 e30 328i M52 track bint.
leeparkes
Wed Sep 01, 2010 11:44 pm
There was a thread ages ago with a guy planning a T5 swap
http://www.e30zone.net/modules.php?name ... vo&start=0
nickso
Wed Sep 01, 2010 11:51 pm
pete sums it up on page three really.
I'm no purist, you can do what you want to a sad old chrome turd, your only temporarily delaying its conversion to a tesco value toaster. What i find strange that with all the readily engine upgrade options out there you would choose to spend vast quantities of money and time reinventing the wheel ?
ross_jsy
Fri Sep 03, 2010 4:48 am
Good engine and can make big power. But at the same time you have to think, is it worth going to all this hassle and experimenting fitting the lump in when an m50/52 is well documented and (if you check out gunni's recent post) can handle a lot of boost without much work.
N00b
Fri Sep 03, 2010 5:05 pm
ross_jsy wrote:Good engine and can make big power. But at the same time you have to think, is it worth going to all this hassle and experimenting fitting the lump in when an m50/52 is well documented and (if you check out gunni's recent post) can handle a lot of boost without much work.
Didn't Gunni state that turboing the M50 comes in at around £4k? Then add another grand for the usual M50 transplant costs and you're in for 5 large. You could probably do the T5 transplant for a lot less although granted you'd also have a lot less BHP too.
ross_jsy
Sat Sep 04, 2010 1:27 pm
Well price up a MLS h/g, ARP head bolts then mani, turbo and management. I'm sure if you scrounged/fabbed a lot it would cost less
That is for 500hp, so see how much it is to get the t5 to that.
Rodderz
Sat Sep 04, 2010 1:36 pm
IIRC I was the only person on that thread who had actually had, and lived with a T5 and my advice was DON'T DO IT!! I hated the way the engine performed in an everyday enviroment!
N00b
Sun Sep 05, 2010 8:52 pm
ross_jsy wrote:Well price up a MLS h/g, ARP head bolts then mani, turbo and management. I'm sure if you scrounged/fabbed a lot it would cost less
I agree, but remember some people don't want 500bhp because the rest of the car will require serious money to uprate everything else. If you wanted 500bhp then perhaps turboing the M50 is the way to go, but if 300 was enough then the T5 lump would be a cheaper way to go.
N00b
Rodderz wrote:IIRC I was the only person on that thread who had actually had, and lived with a T5 and my advice was DON'T DO IT!! I hated the way the engine performed in an everyday enviroment!
In what way?
baptie0
Sun Sep 05, 2010 9:39 pm
I can speak from experience as I have owned two Volvo 850 t5 models, the engines are very good, fast and reliable. Having an alloy block and one cylinder less than an m50 makes it lighter too. 300 hp is the limit on the standard con rods, so any more power than that and its m50 that makes more power per pound when turbocharged.
salty
Fri Oct 01, 2010 10:06 am
Thanks to all the people who left positive and useful feedback,
To all the nay Sayers, get a life and watch this space!
gareth
Fri Oct 01, 2010 11:47 pm
I've been mulling this over for ages, seems the ideal way of getting decent enough power and an amusing compromise on the old 4 pot v 6 pot debate!
If it can be made to work for sensible money then i'd give it a go for a track car. I love the noise of a 5 pot too :cool:
salty
Sat Oct 02, 2010 9:01 am
Any ideas on mating the original getrag gearbox to the t5 engine?
nickso
Sat Oct 02, 2010 4:20 pm
theres an adaptor plate available, not cheap though, give me a while and i'll find it.
nickso
Sat Oct 02, 2010 4:30 pm
e30mtec
Sat Oct 02, 2010 4:40 pm
seriously is this possible?i am very tempted :D :D
nickso
Sat Oct 02, 2010 4:47 pm
anything is possible, how much time and money do you want to throw at it?
e301988325i
Sat Oct 02, 2010 4:53 pm
baptie0 wrote:300 hp is the limit on the standard con rods,
That seems very measly for 2.5L engine that wears a turbo from the factory.
I said:
e30topless said:
lock the wife in there
baptie0
Sat Oct 02, 2010 9:20 pm
The t5 engines are 2.3, some people have made more power but the rods are the weakest link.
http://forums.turbobricks.com/showthread.php?t=10961
N00b
Sat Oct 02, 2010 11:14 pm
According to the article you've linked to above, the standard rods are good for 320-340 WHP if the engine is tuned properly. This translates to somewhere in the region of 380-400 bhp at the flywheel.
baptie0
Sat Oct 02, 2010 11:23 pm
N00b wrote:
baptie0 wrote:
e301988325i wrote: That seems very measly for 2.5L engine that wears a turbo from the factory.
whats your point? the rods are still the weakest link.
Raj_p
Sun Oct 03, 2010 2:12 am
Go for the T5 transplant :)
I have got a V70 T5 and had it for the past 2 years. A great engine, even for day to day use, ive done 80,000 miles in ownership, with clock now reading 187,000. Great cruiser and awesome power delivery when planted.
Theres a lot of modding that can be done to gain big BHP figures.
As stated above, you will need to replace the rods if you decide into 300+bhp however i do know someone running 346bhp on standard engine and not had any issues in the 6months of use
Only real men get it done with an M20
N00b
Sun Oct 03, 2010 8:44 am
baptie0 wrote:whats your point? the rods are still the weakest link.
My point is you're making it look like the engine has relatively fragile internals, when the truth is there are a lot of engines that would need internal work to get over 400bhp.
your quote wrote:The other level is one in which the turbo is upgraded, and performance is limited mainly by the transmission and later, the connecting rods.
Seems to me that the turbo is the weakest link if you're aiming for high bhp. Sorry, but when you state as a matter of fact that 300bhp is the limit on the factory rods, then go on to quote an article written by someone who clearly knows far more than either of us on the subject which states that this is simply not the case, then you have to expect someone to point out that you're less than correct.
baptie0
Sun Oct 03, 2010 12:13 pm
your not bringing anything to this thread, you and the rods are the weakest link, goodbye :D
N00b
Sun Oct 03, 2010 12:58 pm
baptie0 wrote:your not bringing anything to this thread, you and the rods are the weakest link, goodbye :D
Well done for stopping short of putting your thumbs in your ears and sticking your tongue out. This is a discussion which, in case you don't know, means people contribute their thoughts and opinions on subjects and a consensus is reached.....in this case it's been shown that you were incorrect. Deal with it like a grown up, it's happened to all of us.
You say the rods are the weakest link.....the expert reference you cite says the turbo is the weakest link followed by the transmission (not applicable in this case) then the rods.
You say the rods a limit the motor to 300bhp or so.....again, the reference YOU PROVIDED says otherwise and that it's the turbo that needs to be replaced before going beyond 300bhp or so and that the rods can comfortably handle 380@ the wheels.
Out of curiosity, what would a turbo'd M50/52 weigh (as well as intercooler/other turbo associated parts) compared to something like the T5 lump which has a turbo as standard?
baptie0
Sun Oct 03, 2010 1:11 pm
M50 turbo weighs a ton, t5 is alloy so considerably lighter, also its shorter so less weight in front of axle.
N00b
Sun Oct 03, 2010 2:01 pm
baptie0 wrote:M50 turbo weighs a ton, t5 is alloy so considerably lighter, also its shorter so less weight in front of axle.
You're definitely making a good case for making the transplant. I'd imagine the engines aren't stupidly priced in the breakers yards, so even if you had to change the turbo (no biggy as you'd have to buy one to FI the M50 anyway) AND replace the rods you could get big power for somewhere around the same money as turboing the BM lump costs. I think Gunni was throwing around a figure of £4k to turbo the M50, so the Volvo lump looks like a very good alternative to BMW's newer offering. Plus in terms of durability we know the standard Volvo engine is as tough as the proverbial hob nail boots. Any ideas how much the engines change hands for?
baptie0
Sun Oct 03, 2010 2:36 pm
Best to buy a whole car and sell what you dont need, the 850 t5 models are very cheap.
nickso
Sun Oct 03, 2010 3:48 pm
depending on sump options it may have to sit in the same place as the m50 anyway. lighter? yes, better position? mmmmm maybe.
baptie0
Sun Oct 03, 2010 7:34 pm
the sump is a problem, but you can use a front bowl sump from a 24v 960 volvo and chop one cylinders space out of it, then tig weld it back together.
