Intercooler Placement?
Posted: Sat Sep 03, 2005 12:51 pm
Right then i need an intercooler as the hot whether and compressed air is sapping power and helping it detonate i think.
The problem is where to put one, i don't want to be grinding away half the front slam panel or the like.These are the locations i've thought about any more shout them at me. By the way i have an oil cooler.
1)Behind the kidney Grills This seems like a good place to put it as it would have good air flow to it and a bit of protection from the grills, i'e no large stones taking out half a 'cooler. The problems with it i think are- how much air flow will it stop from reaching the radiator as i don't want it overheating. The second problem how to get the hoses to the intercooler, i would guess just chop the plastic radiator funneling, but will that also reduce flow to the rad.
2)Adjacent to the radiator This would be mounted behind the passenger headlight, space is a problem with anything other than a small intercooler hitting things like the power steering pump and abs pump(possibly) Also air flow is't that great as the radiator funneling directs air away from that area.
3)Underneath the oil cooler This would be mounted underneath the oil cooler on the lower front panel(metal bit). It would have to be something like an 820 or cosworth intercooler as they are not very deep. This would have very good air flow. Problems with this are it will be very close to the ground and stones/bumps will proabably kill it very quickly.
So what are your thoughts and any other ideas, i know Ant, Mark and Alex must have some alternatives too, so any suggestions from you guys would be good too. Aswell as location what types of Intercooler, cosworth saabs, rovers.
Cheers in advance
Jon
Cheers in advance
Jon
