gearbox for s50 conversion
Posted: Sun Oct 18, 2009 5:59 pm
by e30mazm3
Ive got a manual gearbox from an E36 1995 320i and propsaft, would this be ok to fit the s50b30 or does it HAVE to be 328 box and prop.If so whats the difference?
It is to be fitted to my E30 316.
Re: gearbox for s50 conversion
Posted: Sun Oct 18, 2009 6:05 pm
by Jhonno
Doesn't make a difference what e30 you are fitting it to..
I would be dubious about the clutch being up to the task. 328i boxes and props are hardly expensive..
Posted: Sun Oct 18, 2009 6:09 pm
by e30mazm3
What difference is the clutch going to make to the gearbox?
Re:
Posted: Sun Oct 18, 2009 6:31 pm
by DanThe
You wont get a 320i box over the S50 flywheel/clutch
Re:
by Nath325i
Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
Re:
Posted: Sun Oct 18, 2009 6:32 pm
by DanThe
Use an M20 clutch 8)
Re:
Posted: Sun Oct 18, 2009 6:52 pm
by e30mazm3
Nath325i wrote:Think youll find he means putting the all the power of an S50 through a 320 clutch, might have trouble coping
Im with you. Wouldnt attempt 286 horses through a 320 clutch!
Re:
Posted: Sun Oct 18, 2009 6:53 pm
by e30mazm3
DanThe wrote:You wont get a 320i box over the S50 flywheel/clutch
So has the 328 box got a bigger bell housing than he 320. is that the difference?
Posted: Sun Oct 18, 2009 7:52 pm
by e30mazm3
So will the propshaft be the same?
Re:
Posted: Sun Oct 18, 2009 8:53 pm
by DanThe
Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
Whats wrong with a 320i clutch? Apart from the weight issue! Im quite sure it would be fine TBH
Re:
Posted: Sun Oct 18, 2009 9:20 pm
by e30mazm3
DanThe wrote:Props are different, so is 90% of the gearbox. 2.8 uses a ZF large bell housing box, most 2.0's use a Getrag box
Thanks for the info danthe. that is some serious BM knowledge! Respect
