Engines!
Posted: Thu May 28, 2009 2:33 pm
by Rickbmw1984
Hi,
Im looking in to the possibility of an engine swap from my 2.7. What are the best engines to put in an E30?
I have been looking at 3.5 but this seems quite complicated with shortening props, customs mounts etc. Is there any direct swaps?
Cost needs to be relatively low but I can of course sell my current engine to recoupe some funds and maybe sell my lsd!
The newer E36 engines appeal to me due to them having more power in the smaller engine sizes”¦..a newer 325i engine would be a nice addition.
What do people suggest?
Re: Engines!
Posted: Thu May 28, 2009 2:36 pm
by rix313
What do you have at the moment?
Re: Engines!
Posted: Thu May 28, 2009 2:53 pm
by ImysE30
Rickbmw1984 wrote:Im looking in to the possibility of an engine swap from my 2.7.
Do you have a budget in mind? How handy are you with spanners?
M30 is cheap and easy to do. Just need mounts (beefy on here sells them) and a custom prop (around £100).
M50/52 is not that expensive but the manifold modifiying is the major issue
Re: Engines!
Posted: Thu May 28, 2009 3:02 pm
by Rickbmw1984
Budget isn’t a real issue but cheaper the better. Im currently gathering in money from selling my mk2 golf gti (if anyone is interested in it its mint
) selling few bits off my nova and astra and also I could sell the engine from my E30. It’s a M20B27 oh and the LSD.
Just wanting more usable power as all my power currently is top end also wanting more power. I could spend money on my current engine but by the time I got the power I want I would have spent more than I would just by dropping in a better engine.
Re: Engines!
Posted: Thu May 28, 2009 4:05 pm
by ImysE30
M30 is probably the cheapest conversion to do and 200BHP
. Donor car can be had for around £300-£400, shouldn't cost more than 1k if doing yourself
Quite a few swaps on here for the M30, leeparkes has just finished his
Where are you based?
Re: Engines!
Posted: Thu May 28, 2009 4:15 pm
by Rickbmw1984
Based in Leyland near preston.
Yea looking around for a donor car as we speak. I presume it doesn’t matter whether I get a 535 or 635? And auto or manual?
Im currently doing a red top nova conversion and a redtop kit car so im pretty clued up on engine swaps at the minute!. I presume it would be best to get the entire car and not just the engine and loom?
Re: Engines!
Posted: Thu May 28, 2009 4:21 pm
by Rav335uk
You'll have to keep the LSD if your going for more power, don't sell it.
M30 is an easy job to do, can be done in about 3 days if all parts are to hand.Chech out the sticky on the m30 in the engines,swaps thread.
Re: Engines!
Posted: Thu May 28, 2009 4:29 pm
by ImysE30
Rickbmw1984 wrote:Based in Leyland near preston.
Best to get a E34 535i manual. Depends if you want an auto or manual really.
Best to get the whole car IMO, that way you have most of all the parts you need
Re: Engines!
Posted: Thu May 28, 2009 4:46 pm
by Rickbmw1984
Ill have to keep my eyes open for a full car and in the meantime obtain a prop and engine mounts etc. All the E34 535’s I can see are about £1000 so will need to keep looking!
If you know of any then do please let me know.
Re: Engines!
Posted: Thu May 28, 2009 4:49 pm
by ImysE30
Manual one's are slightly more expensive as they are rarer, you should be able to pick one up for around £500 i reckon
Just keep an eyeout on eBay and Pistonheads. There are a few on eBay at the moment IIRC
Re: Engines!
Posted: Thu May 28, 2009 5:46 pm
by fowler
keep the 2.7 and find out what is wrong with it as it must dodgy if all the power is top end
unless it has stupidly high lift cams in it.
Prob duff engine componet as most 2.7 are really grunty engines from 2.5k to the redline.
Are you sure its a 2.7 ?????
Re: Engines!
Posted: Thu May 28, 2009 5:53 pm
by Rickbmw1984
yea it isnt running right i know that its on the wrong ecu for a start and needs a service.....but i like the idea of a 3.5! it is still powerful low down but isnt quick....it perks up big time at 5K upwards.
Re: Engines!
Posted: Thu May 28, 2009 6:46 pm
by fuzzy
isnt a healthy 2.7 about 200+bhp anyway? not much gain to be had in puting a 3.5 in.
Re: Engines!
Posted: Fri May 29, 2009 8:50 am
by Jonsku
Rickbmw1984 wrote:Im looking in to the possibility of an engine swap from my 2.7. What are the best engines to put in an E30?
Best, well that's quite hard question but M30 and M50 are almost straight "plug'n'play" and cheap.
If i'd be doing easy budget swap i'd pick M50 and get some 2.8 stuff in it + some ecu tuning. => 250hp easily and with relatively little cost
maybe sell my lsd!
No, that's totally wrong place to get money from. You'll definitely need LSD with more power..
Re: Engines!
Posted: Fri May 29, 2009 9:27 am
by Rickbmw1984
250bhp is about the power i want to go for so ill look in to that as well.
Re: Engines!
Posted: Fri May 29, 2009 3:53 pm
by GrindCulture
V8 the fucker
Re: Engines!
Posted: Sat May 30, 2009 4:22 am
by Benho
m52 with m50 manifold. that alone is around 230 iirc. plus a few bits and bobs and your looking at a nice little lump. like said before keep lsd!
