Leccy fan size..
Posted: Thu Mar 05, 2009 11:13 pm
by Jhonno
What size leccy fans is everyone running on their 24v or even just 12v boat anchor swaps?
Looking at a slimline ones @12", but thinking it might be too small..
Re: Leccy fan size..
Posted: Thu Mar 05, 2009 11:35 pm
by jmc330i
I think mine is a 14" Spal, its what Toby had on his M30 Turbo.
I will check the size tomorrow.
Posted: Fri Mar 06, 2009 10:36 am
by winx
e34 aircon fan infront of the rad, as soon as it kicks in seems to do a very good job!
Posted: Fri Mar 06, 2009 11:21 am
by DRIFTBOY
I reckon that would work fine Johnno.
I'm using a 14" Spal on the M30 turbo and it does a great job, with E28 535i radiator.
Re:
Posted: Fri Mar 06, 2009 2:44 pm
by bigdek
i used a totty peugeot 205 fan on my m30 and it worked just fine
Posted: Fri Mar 06, 2009 8:20 pm
by ian332isport
Dan,
14" is the biggest you can fit on the M3 radiator. I initially used a 14" Pacet Profan, but replaced this with a regular E30 aircon fan (also 14") when I fitted the aircon.
Ian.
Re:
Posted: Fri Mar 06, 2009 9:52 pm
by jaistanley
I'm now looking for one for mine (who thinks I can get this car on the road in two weeks of graft and spending???).
Does anyone have any wiring diagrams and part numbers for making my own 2 speed fan controller that will work with a pacet 14" fan??
Cheers guys.
Jai
Re:
Posted: Fri Mar 06, 2009 9:54 pm
by Jhonno
Posted: Fri Mar 06, 2009 10:00 pm
by Simon13
winx wrote:e34 aircon fan infront of the rad, as soon as it kicks in seems to do a very good job!
Alpina B6's used this setup
I've got an E30 M3 electric fan taking up space if anyone wants one
Posted: Fri Mar 06, 2009 10:06 pm
by Jhonno
What does it look like Si?
I have something in there, but the frame for it takes up too much space and I can't mount my oil cooler..
Posted: Fri Mar 06, 2009 10:13 pm
by Simon13
I'll dig it out, but i'm sure its a bolt in job infront of the radiator with enough room for an oil cooler
Posted: Tue Mar 30, 2010 10:47 am
by RoadHazard
Is the E34 fan a direct fit? Or do I need some custom job to make it fit?
Right now I have the 5-blade E30 air con fan. Will this be adequate?
Posted: Tue Mar 30, 2010 2:05 pm
by jmc330i
I think Ian332i is running the E30 air-con fan, so it should be up to the job - Ian doesnt cut corners or accept poor substitutes
Posted: Tue Mar 30, 2010 5:41 pm
by ian332isport
Yeah, I'm running a bog standard E30 A/C fan as my only cooling fan. It was actually from an M3, but I don't believe there's any difference.
I think it's also worth using the temperature switch from the E36 318 compact, as it switches on sooner.
Cheers,
Ian.
Posted: Tue Mar 30, 2010 7:50 pm
by rix313
I'm running an 11" SPAL push fan on the track car, been ok so far. I have a couple spare if you need one.
Posted: Tue Mar 30, 2010 8:36 pm
by E30BeemerLad
I used a M3 electric fan on mine with the M52 rad from the E36 and it did a sterling job for the month I had it on the road
Posted: Wed Mar 31, 2010 6:29 pm
by RoadHazard
Cheers,
Ian.
Thanks Ian. That's good to know.
Went out to buy a temp switch from E36 318 today. I need anything that could help because I'm in a hot climate. I'm thinking about running no antifreeze like some folks in US because it never gets below 10 degree C where I live but I'm not sure if it's a good idea.
If the E34 air con fan is worth getting, I'll try to find one too.
Posted: Wed Mar 31, 2010 11:02 pm
by ian332isport
RoadHazard wrote:I'm thinking about running no antifreeze like some folks in US because it never gets below 10 degree C where I live but I'm not sure if it's a good idea.
I really wouldn't advise it. Antifreeze obviously stops the coolant from freezing, but more importantly, it has corrosion inhibitors.
Without these, your engine will slowly digest itself from the inside and the cooling system will silt up and make matters worse.
Ian.
Posted: Tue Apr 06, 2010 6:22 pm
by RoadHazard
Alright. Got some antifreeze from BMW ready to be mixed and poured in. Just need to hook up a hose from the engine to the expansion tank. Can't source a good hose that has the right bends yet.
I'm going to use the 5-blade AC fan for now. Do I have to modify the fan circuit or I can leave it the way it came from the factory?
