316i to 325 engine conversion
Posted: Sun Nov 09, 2008 9:34 pm
by pac1982
Just got my self a 316i lux coupe, been after a E30 for some time and ideally i wanted a 325 but when i came across this 316 which was in lovely condition I had to have it.
My question is how straight forward is a engine swop for a 325 lump?
I’d also like to upgrade to rear discs is this just a case of swapping parts straight over of is there some modification involved?
Re: 316i to 325 engine conversion
Posted: Sun Nov 09, 2008 10:27 pm
by leeparkes
quite an easy straight forward swap
been done plenty of times
Posted: Sun Nov 09, 2008 10:37 pm
by town325i
if your going to swap the rear to discs it would worth while putting new bushes in at the same time not to dear from the dealer either
Posted: Sun Nov 09, 2008 10:42 pm
by pac1982
How much needs to be changed for a rear disc set up? do they just bolt on where the drums used to be or do you need to swop the whole lot over?
Posted: Sun Nov 09, 2008 10:44 pm
by town325i
you need the trailing arms that came with discs and fit those to your car
Posted: Mon Nov 10, 2008 6:00 pm
by pac1982
I think my best bet would be to source a crash damaged 325 or one with a really rusty body then I can get all the bits I need for the engine and rear disc conversion from the same car and save quite a bit of cash while I'm at it.
Does it matter what year I buy?
Posted: Mon Nov 10, 2008 8:17 pm
by snoops
Not really but a facelift would be preferred as it will just plug straight in. You could get a pre facelift but then you'd have to change the engine loom for a facelift.
Keep your eyes peeled on ebay and the for sale section on here, plenty of cheap engine donors come up.
HTH
Posted: Tue Nov 11, 2008 5:58 pm
by hongkongfuey
hello mate, 325rick has a 325 engine and gearbox for sale.
Posted: Tue Nov 11, 2008 6:06 pm
by pac1982
cheers for the info but I'm not looking to buy the engine/donor car till the summer going to focus on finding the mtec bumpers, bbs alloys and leather seats first off unless of course a good donor car comes up with loads of the bits I'm after.
Been looking at a few 325 estates they seem to sell for a few hundred quid, anyone know if I can use the rear discs and arms from a estate on my coupe?
Posted: Tue Nov 11, 2008 6:29 pm
by hongkongfuey
yep, and they are known as touring's not estates. i don't care what you call them but some on the zone are quite anal about it
Posted: Tue Nov 11, 2008 6:48 pm
by GrindCulture
The rear on a touring is the same as a saloon, only the springs are different (to cope with the extra weight). All tourings have rear disks, no matter what engine.
Posted: Tue Nov 11, 2008 9:32 pm
by Brianmoooore
For a safe and roadworthy conversion of a 316 saloon, you need to use the entire suspension and brakes (with appropriate springs), from a 325 saloon, any touring, a 318iS or any cabriolet.
Posted: Wed Nov 12, 2008 12:20 am
by e30-unit-soldier
snoops wrote:Not really but a facelift would be preferred as it will just plug straight in. You could get a pre facelift but then you'd have to change the engine loom for a facelift.
HTH
Sorry for hijacking thread but i think ive been posting wrong thread
I wanna do the same conversion on my 318i jreg cab is it better that i get a facelift 325i donor car? as you are saying that the wiring would be just ready to plug in? or have i lost it completely
Posted: Wed Nov 12, 2008 10:41 am
by pac1982
I think that may be the case
Posted: Wed Nov 12, 2008 1:57 pm
by Brianmoooore
completely plug and play, EXCEPT, check out my wiring warning sticky thread at the top of this forum.
It probably won't apply to a J reg cab, but it's worth making sure!
Posted: Sun Nov 30, 2008 7:19 pm
by zimm_zimmer
so if i were to get a 316 and get a 325 engine, box and diff i would not require anymore than this or would i require the ecu and is there anything else as sometimes and engine doesnt come with everything such as afm, many thanks for any info.
Re:
Posted: Sun Nov 30, 2008 7:55 pm
by initial_g
from experiance (ive done afew honda swaps) buy a accident damaged 325 and frag the parts of that itl work out cheaper in the longrun
Re:
Posted: Sun Nov 30, 2008 8:55 pm
by Brianmoooore
A complete engine includes the wiring loom, ECU, and AFM/filter. You'd also need the radiator, oil cooler (or a 320 oil filter), gearbox linkage and prop. and probably one or two other bits I haven't thought of.
The 316 had better be a touring or a cab, as well!
Posted: Sun Nov 30, 2008 9:10 pm
by zimm_zimmer
so why cant it be fitted to a saloon, are they shorter or something, it seems like a lot of money is envolved, i only ask as i got my pug 306 im trying to shift for an e30 and been offered a 316
Re:
Posted: Sun Nov 30, 2008 9:16 pm
by pac1982
Since my 316 has now been written off my plans have changed a bit gonna use my insurance payout to buy a nice E30 which already has the engine and leather what sort of money am I gonna have to spend to get a tidy fully loaded 325 sport?
by GrindCulture
zimm_zimmer wrote:so why cant it be fitted to a saloon, are they shorter or something, it seems like a lot of money is envolved, i only ask as i got my pug 306 im trying to shift for an e30 and been offered a 316
I can be dropped into a saloon but the cabs and tourings have the appropriate brakes and suspension (bar the front springs).
