Short Vid of A-Techs Work 2.7 Turbo, Speedo
Posted: Thu Aug 21, 2008 12:47 am
by gadjit
Hi All,
Not posted for a while, went out in the old girl a few weeks ago
and took this short Vid
http://img532.imageshack.us/my.php?imag ... edopc1.flv
Hope it works
Gadjit
Re: Short Vid of A-Techs Work 2.7 Turbo, Speedo
Posted: Thu Aug 21, 2008 1:04 am
by oakey
Awesome
That is very quick
Above 100mph its ridiculous!
Posted: Thu Aug 21, 2008 1:06 am
by Jon_Bmw
Thats fast
A rough guess looking at that, 13 seconds to a 100mph and 20 seconds to 135mph. Nice car sir.
Posted: Thu Aug 21, 2008 1:11 am
by gadjit
Thanks Guys
Me do love me 30.
Had to hold off in 5th cos there was something called an Island coming up pretty quick
Was also Taking off in a lay by, behnd a Truck,.
Thanks again
Gary
Posted: Thu Aug 21, 2008 7:46 am
by fowler
Gary thats quick i will have to get project fridge out and we can go hunting for some scalps
Posted: Thu Aug 21, 2008 7:58 am
by DanThe
That would do a great 1/4 mile time!
Posted: Thu Aug 21, 2008 1:11 pm
by E30BeemerLad
that must be a 12 second 1/4 mile car I reckon
Posted: Thu Aug 21, 2008 1:56 pm
by Phill172
Very very nice....whats the spec?
Just need to get mine sorted now!
Posted: Thu Aug 21, 2008 4:09 pm
by e30bmlover
fuck thats fast....
i would like a similar result when i supercharge my b25... no lag...
Posted: Thu Aug 21, 2008 4:11 pm
by daimlerman
What diff ratio are you using,please?
Posted: Thu Aug 21, 2008 4:25 pm
by gadjit
Thanks Guys
Spec of my 30 is as follows
Engine Spec
Fully rebuilt 2.7 Engine
Alpina C2 2.7 Head.
Polished Crank
All new M50 shells, (Crank, Rods)
New Piston Rings
New OE Alpina Valves 11 34 107 exhaust valve, 11 34 106 inlet valve.
Double valve springs
Turbo Cam
New eccentric rockers
New Valve stems seals, and oil retainers
New spray bar
New High Pressure Oil Pump
44 LB Injectors,
High pressure fuel pump,
Holsett HX45 18 CFM Turbocharger
Wideband controller
Tial Wastegate
Megasquirt
Aluminum Intercooler and Pipework
Polished Rocker and Inlet Manifold
Scorpion Exhaust
Suspension & Handling
White line Heavy duty Anti Roll Bars,
Polybushed Everywhere,
KW Coilover suspension
Refurbed Compomotive MO Alloys, Smoked Chrome Inner / Polished Lips
215/35/17 Yoko S Line Front
225/35/17 Yoko S Line Rears
Strut Braces Front and Rear
Braking
Front
AP Racing 4 Pot Calipers
330 mm Discs
Greenstuff Pads
Rear
WMS 4 Pot Calipers
280 mm Discs
Greenstuff Pads
Drivetrain
5 speed Sport Gearbox
Helix Double Competition clutch
M3 Thrust Bearing
E30 M3 Twin clutched LSD 3.25 Drive 15-90 % lock Ratio
E36 M3 Diff Oil
MTEC 2 Alcantara 370 mm Steering Wheel
Complete Retrim, Black / Silver Inc Doorcards
New Genuine Front wings
Fully Resprayed, Inc Engine Bay
Black Ellipsoid Angel Eyes
Smoked back / side lights,
Black Grill,
Black/silver Carbon roundels
Tinted Windows
Total closure alarm,
Aluminum Pedal set
Parrot Bluetooth kit
Ant could add to the list of the engine spec, as he built it.
She is pretty quick and quite often scary,
but on a nice warm day i don't want to get out of Her.
Thanks again
Gary
Posted: Thu Aug 21, 2008 5:13 pm
by 325eye
Love it
Posted: Thu Aug 21, 2008 5:21 pm
by georgen
Amazing. What a machine !!
Posted: Thu Aug 21, 2008 11:31 pm
by 1an
Gary,
awesome car btw,
what do you think of the whiteline anti roll bars?
Posted: Thu Aug 21, 2008 11:41 pm
by gareth
that's rapid! nice work!
all on a private runway yeah?
incidentally, how have you got 280mm WMS 4 pots on the rear?
by Karan
WOW fast indeed what sort of power does she make?
Posted: Fri Aug 22, 2008 9:24 am
by fowler
384bhp karan with potentional for more
Posted: Fri Aug 22, 2008 10:13 am
by gadjit
Hi 1an
the whitelines are OK over stock,
but really do need to be Poly bushed for any real effect,
Hi gareth, i originally bought the WMS Kit from kerri for the front,
they did do the trick, but the brakes still felt a bit spongy,
my wife debby then found an Alpina C2 2.7 ON THE BAY,
and won it as a present for me for £1230.
When i picked it up, it had a host of trick bits including the AP 4 Potters,
and Compomotive MO's
I decided to swop over the front calipers etc, and the WMS Kit sat in my garage for a while
A neighbouring Business of mine said that they could make them fit by altering and
machining a new bracket, so i took the old girl down and left it with them,
If you like i can get the plan or drawings of the machining and bracket that they used,
I must say tho, that i havn't felt really any difference by fitting these over standard to the rear,
but they certainly do look trick.
Regards
Gary
@ Fowler, hows the Fridge Dude, is she coming to the Pod ?
Posted: Fri Aug 22, 2008 10:47 am
by fowler
gary i hope it will be ready for the pod has had some more trick bits fitted and needs more boost and i can say i hope it will be there we can ripup some tarmac
glad yours is all good. will have to catch up over a tea at Pod
you coming down the workshop anytime soon ???
Posted: Fri Aug 22, 2008 11:48 am
by d1mmy
Still looking good Mate.
Shame no Bentleys around
Posted: Fri Aug 22, 2008 1:39 pm
by gareth
I'd be interested to see how you fitted them actually. the piston area on the rear will now be a long way out, though it's all relative to the pistion size on the front. i suspect you have a heavy rear bias now....
what discs did you use? and do you stil have a handbrake?
Posted: Fri Aug 22, 2008 1:44 pm
by maxfield
Proper!
Posted: Fri Aug 22, 2008 3:09 pm
by GrindCulture
That's one hell of a machine!
Posted: Fri Aug 22, 2008 4:37 pm
by JazzMan
Awe-inspiring stuff!
Posted: Sat Aug 23, 2008 7:16 pm
by Alburglar
Not very clever. The engine isn't up to temp
Posted: Sat Aug 23, 2008 7:47 pm
by oakey
Alburglar wrote:Not very clever. The engine isn't up to temp
Yes it is. Remember the camera is looking at it from harsh angle.
Posted: Sat Aug 23, 2008 8:44 pm
by JazzMan
It might be it was, I've seen them sitting over there on full temp.
Posted: Sat Aug 23, 2008 8:54 pm
by fowler
i can clearly say that the engine is fitted with a tropical climate Stat so it rarely goes over a 1/3 temp in this country so don't be alarmed at this as the car is very well looked after.
Posted: Sat Aug 23, 2008 9:00 pm
by e30topless
that is quick ! Love it
Posted: Sat Aug 23, 2008 10:09 pm
by sk712
Jesus Christ, that's dangerously fast!!
Posted: Sat Aug 23, 2008 11:56 pm
by oguz327
Posted: Mon Aug 25, 2008 7:32 pm
by H35-IAN
